where i am, we have to have the oil in containers that close to drop it off. we don't get to pour it out.
i have yet to have a problem with the drain pan. i just hold it up to the plug, remove the plug, and let it flow, lowering the pan down after the first couple of seconds. clean, simple, fast, and FREE.
i definitely do not want to leave oil in something like that, so it would have to be thoroughly cleaned after each use. i even wipe out my drain pan with brakekleen after each use. in fact, i have 3 different pans, one for each type of liquid. i never mix them.
but, if you are not going to remove the plug, i can see the advantage of sucking it out, assuming it can be done. i only see added work otherwise. it will be interesting to see how much comes out. anything much less than 6 quarts though, and it isn't enough. that leaves too much oil, and the dirtiest oil at that, still in the pan, ready to find its way back up into your engine.
a simple petcock on the drain plug would be a much more viable solution, though it would still require lifting up the car a bit.
www.968forums.com
