Threads: 77
I only run synthetics. Someone from Europe will probably chime in on what they are using.
Threads: 45
These engines were designed and built before the real rise in synthetics, but that does not exclude their use
Take a look in your hand book and look at the rating for your temp range that will give you a guide as to grade considering where you are.
My car is quite high mileage at 143K I have run Shell Helix HX7 and high quality 15W40 mineral oil, and my car is happier on the mineral oil.
The lifters are quiter and the oil pressure higher after a long drive,
Oil is such a subjective topic and you will get a 1001 opinions but I would pick the best oil for your temp range regardless of synthetic or mineral, mainly because it will be better than the unknown stuff you currently have in the motor.
And I would avoid Mobil 1 as that has one of the lowest ZDDP counts
And that's an opinion only
Threads: 15
I've had good experience with Motul synthetic and it's highly rated.
Current: 1994 968 Coupe, 1987 944S, 2004 VW GTI 1.8T, H-D XR1200
Previous Porsches: 2000 986S, 1974 914 2.0 Blue, 1974 914 2.0 Yellow, 1970 914 1.7, 1985 928S
Previous non-Porsche favorites: 1974 Early Bronco, 1975 Cosworth Vega, 1977 Trans Am 6.6L, 1973 Karmann Ghia, 1983 Supra (turbocharged)
Threads: 49
I thought the Mobile 1 15-50 still contained sufficient amounts of zinc. I recall reading that it was the only one that they made with the right amount of ZDDP. Anyone know if this is still true?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
Millers CFS 20W50 nano technology get good reports here with 1200ppm ZDDP
Threads: 59
I've been running Total mineral oil, which has a a high ZDDP content, on the advice of my mechanic. The car now has about 160K miles on it and no issues with the engine. Total is a French product.
Chris Vais
2008 Audi A5 Brilliant Black
Threads: 45
I have to say that in the UK manual 0w40 does not get any kind of mention, I would suggest that the OPC is just going by the A30 recommendation with out looking at the correct spec for the car
the other issue with 0W40 is that it is an SM API oil and has less than 800ppm ZDDP, I think I would check that with your OPC again or even better give an indie that knows these cars a ring, JMG, HARTECH, and see what they have to say
OPC these days have probably not seen an FE Porsche for ten years
Threads: 45
It's the API SPEC that says it all
the ZDDP level was down to 800 ppm in API SM licensed oils. This was mandatory for API licensed oils that were SAE 10W-30 or less. Diesel oils are typically 10W-40 or higher, so these viscosity grades can contain up to 1200 ppm ZDDP in accordance with the API CJ-4 Diesel engine oil standard. However, all of these oils have had increased levels of detergents and dispersants since the late 1990s. This allows for longer drain intervals and helps to keep engines cleaner when they are forced to use exhaust gas recirculation to limit emissions.
If I read that correctly, which I might not
If the oil reaches API SM then it must be less than 800 ppm to meet the standard below 10W30, does that include or exclude 0w40?
API SL was 1000 ppm
So I guess rule of thumb look for oil that meets SL
The other issue is the balance between detergents and ZDDP
(This post was last modified: 03-30-2015, 07:00 AM by
Waylander.)
