+1. Very cool!. I saw last weekend the pictures from the new 911 GTR3. Will those headlights not fit into the guards without modifying them?
[quote name='unknown4u' post='42141' date='Oct 8 2007, 12:46 PM']+1. Very cool!. I saw last weekend the pictures from the new 911 GTR3. Will those headlights not fit into the guards without modifying them?[/quote]
I can't imagine they would... they're not the right shape to at all
[quote name='saxman' post='42129' date='Oct 7 2007, 09:45 PM']it was really the mini cooper headlight that inspired me more than anything, but it is a somewhat similar appearance to the 997. The difference of course being if it's integrated into the headlight lens or not.[/quote]
Sweet ... hope this really happens! I will definitely be a customer. What kind of headlight is this, a 993 or something that would be built from scratch?
(This post was last modified: 10-08-2007, 11:57 PM by badberry68.)
[quote name='badberry68' post='42156' date='Oct 8 2007, 07:54 PM']Sweet ... hope this really happens! I will definitely be a customer. What kind of headlight is this, a 993 or something that would be built from scratch?[/quote]
it would be a stock 968 headlight with lots of custom stuff done to it
[quote name='saxman' post='42158' date='Oct 8 2007, 10:12 PM']it would be a stock 968 headlight with lots of custom stuff done to it[/quote]
I know this is getting a little ahead of things, but once you get the design worked out, how do you envision it being applied to our cars? Would we have to mail our headlights to you for modification (doubtful, as you would probably get buried in headlights!)? Is this something that, with instructions, the average owner could do themselves? Or is it just too early to tell how it will likely go? Thanks.
about 8 lbs or so including armatures and such - the pan is good for another 3 or so
this conversion looks like it might save about 16-17lbs altogether, and off the front end of the car, where it matters most - the savings from the removal my the bumper (about 16 lbs)was definitely noticable - same with the battery
Thanks - that's actually a little more than I expected. Between this, replacement of the battery with an Odyssey dry cell (don't need much in the way of cold cranking amps here in Austin), and an RS Barn cat back exhaust, there's the opportunity to knock off about 75 lbs with no sacrifice. After that, I guess it starts getting a lot harder (and much more expensive...)
[quote name='Cloud9...68' post='42311' date='Oct 13 2007, 09:55 AM']Does anybody (Flash...?) have an estimate as to the weight of the motor drive assembly for the pop-ups? 5-10 lbs, maybe?[/quote]
I have saved about 10 kg. with front lights. Original set up is about 15 kg.
Zoran
WOW Zoran that looks the business mate, <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> what parts have you used and how much did it cost, very interested in that set-up, all the best pazzer.
certainly works for the race car, and the i have to commend the work - clearly a lot of thought went into this - i think something looks a bit "home made" though for a street car
perhaps if the pieces were reflectorized and/or a different color?
i think the problem for me is the entire idea of a lack of symmetry and balance within the stock opening - unless it is a single fixture, set into the opening in a symmetrical and balanced fashion, so that it looks like an orb within an orb (like an eyeball), with a convex lens, i think it is always going to look like it came from a kit car
not sure anybody is going to get there, and that's why i think that if i ever get around to it, i'll likely end up with 996 lights on new fenders - i love the look of the shot in flwbyu's avatar
I would have agreed with you, until I saw Saxman's photoshop rendition of his concept, which I think looks quite nice, and very professional, though it's a little hard to tell without seeing a direct-on image. I (any many others) are dying to see how the finished product will turn out...
yeah - me too - that has the potential to solve both the functional and the aesthetic issues i have with the concept
what i am really waiting for is to see how it is mounted, and how that will result in weight loss, which is really the only reason i would do it
[quote name='flash' post='42695' date='Oct 21 2007, 09:31 AM']certainly works for the race car, and the i have to commend the work - clearly a lot of thought went into this - i think something looks a bit "home made" though for a street car
not sure anybody is going to get there, and that's why i think that if i ever get around to it, i'll likely end up with 996 lights on new fenders - i love the look of the shot in flwbyu's avatar[/quote]
Geez, you're a tough audience Flash. When I think of the factory fixed lights on the 944 turbo Cup cars I think Zoran's looks as good, just the roundness is different. I think the fully sealed 996 type thing could be great, but maybe not at the expense of having a jutting nose piece. Zoran's is the best I've seen so far. Plus any car with 537 hp at the wheels can have whatever lights he wants!! lol
[quote name='EEZATOY' post='42123' date='Oct 7 2007, 04:18 PM']very cool - I like the trim piece, similar too this 997 look...[/quote]
Just running a smidge of neg on the fronts too.
Patrick
(This post was last modified: 10-22-2007, 10:12 AM by 333pg333.)
lol - yes, i am a tough audience - way too many years of building cars, prepping concours cars, yada yada - details drive me nuts - i will frequently spend an hour on little things like matching fender gaps, carefully measuring, and won't settle until they are perfect - stuff that looks wrong makes me crazy - don't get me started on the "push-me-pull-you" twist wheels on the boxster
never noticed the turbo cup cars, but i'll look the next time i see a shot
i'm certainly not knocking his effort - i'm just looking for something that looks more factory than kit - as i said, perhaps different finish treatments might help - definitely a convex lens
what jutting nose piece are you talking about?
Fair enough. I agree that when you see gaps or uneven bodywork it just kills the overall appearance for the car. As you say fine for racecars, but from the pic's I still kinda like Zoran's car. I must check it out next time I'm down in his town. Here's a link to when the car first got done. It's considerably more powerful now. www.rescueforce.com.au/images/race-pi.wmv
Sorry, you'll have to cut and paste the link, but it's worth it just to see the car make the 993 RS CS look like it's standing still on the straight.
Patrick
(This post was last modified: 10-23-2007, 08:06 AM by 333pg333.)
i'm certain that car is silly fast - has to be a blast to drive
[quote name='pazzer' post='42692' date='Oct 21 2007, 04:35 PM']WOW Zoran that looks the business mate, <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> what parts have you used and how much did it cost, very interested in that set-up, all the best pazzer.[/quote]
Steady on Chris - you've done enuff <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
