NEW FRONT SPLITTER - FINALLY
everybody knows all about the porsche motorsport splitter - they also know about the fiberglass replicas - we all know the ups and downs of both - personally, i had gotten tired of having to repaint the danged thing every time i drove the car - the edge at the front of the splitter would grab things and curl under, thereby cracking the paint, requiring a repaint - this would happen nearly every time i drove the car, because it is so danged low - i modified it to include delrin skid plates at the corners, which worked great on burms and such, but the center area was too flexible to allow bonding agents to hold
i also did not like the "stuck on" look the motorsport unit has - it gets sandwiched between the bumper cover and the front apron, and to me just looks like an afterthought (well, it really is) - i didn't like the black underneath, and painting the apron blue, or the splitter black was not an option either
it ss, however, very functional, so i was determined to have something up there
i had seen this different one on a yellow car in a pic, and had no idea where it came from, but loved the look - i then saw another one in portland at parade - this time i got a chance to get under the car and really check it out - it turned out that it deleted the front apron, replacing it with an integral unit - a one piece wrap around splitter? no chance of curling under? wow! - it is fiberglass, but the design is a dramatic improvement in the area of snagging and curling - front impacts would suck, but that is really not the problem i was having
that was it - i just had to have it - then a couple of months later, it turned out that the one off of the yellow car that i had first seen was up for sale - i ran right down to get it
upon bringing it home, i noticed some flaws in it - but, i also noticed the phone number of who made it - i tracked them down to their new number and called and ordered a new one - eric said he'd take the yellow one - i thought "cool - this will work out for both of us"
well, what i got was not exactly the same - it turns out that the unit was really for a 944 turbo - it was nearly 2 inches wider, with different profiles - it was going to tke a LOT of work to midify the new one to fit like the old one - not being terribly patient or adept at fiberglass work, i opted to instead fix up the yellow one - eric had already started on it, but gave it back to me anyway - he then said he'd take the new one and modify it to match
this turned out to be a huge job (even more for eric), but it worked out in the end and looks great - this is not an off the shelf unit, but i think it looks a lot better than the motorsport unit - i'm adding some delrin skids underneath to prevent scraping, but it looks like it is going to work out great
here are some pics
and here is a shot of mine and eric's
Flash, you really got my hopes up when I saw your "New Front Splitter" subject line. Too bad its not a bolt-on fit. I've seen the turbo splitters and they're a much better product, hands down. Any details on the work involved to take a new splitter out of the box to the point of bolting it on a 968? Are we talking sanding down the extra two inches and shaping or is it much more that that? Any details are greatly appreciated.
John
John
1992 968 E Stock Club Racer
1991 944 S2 (gone and missed)
1990 928 GT (gone and really missed)
Oooh, nice <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Yes, bolt on would be great!
-Ren
i had the turbo splitter - that's the one i was talking about - that's the one that i kept buggering up - it is a bad design that has an edge that would grab every driveway i came out of and curl under - sure it flexed right back, but it knackered the paint in the process
this is much better
it takes a lot of work, involving cutting, splicing and new layup - it also need brackets bonded in - not for the novice - looking at a good 10 hours of work, not counting paint
so, not much chance of it being bolt on unless you are willing to drop a grand for somebody to buy it, modify it, and then sell it to you
They look GREAT!
Very nice work!!
I am not sure I got this right , did you say you have have better luck with fiberglass splitters or polyurathane? I seem to get better wear with less cracking/chipping with the polyurethane?
Miles
Hmm well.. to each his own... <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
Sure the rounded leading edge may be more practical for daily driving and is nicely done, however IMO this new design [I hate to say it] does look like an add-on. And, the main reason is the transition between the lower fender and the end of the splitter. The factory unit has a cleaner transition. Perhaps it's angle that the picture was taken{?}. I suppose someone that's not familar with 968's wouldn't notice that the splitter is an aftermarket unit. So are you sans under-pan now?
Also, many 968's [like mine] have black trim pieces, [i.e. rear spoiler] which is why I chose to go with black. Additionally, since I knew I'd have to touch up the paint, I went with semi-gloss bumper black which doesn't crack. I can do the touch-up myself in a short time without removal.
I know opinions are like belly-buttons, but thought I'd toss in my .04 worth... <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
I'm I off the x-mas card list now... <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" />
to be clear, it is not a generic answer on the fiberglass / poly question - it's all about the design
poly flexes more allowing for some give - fiberglass is unforgiving
let's clear on thing up though - the "factory" unit was not from the factory - it was also an aftermarket unit, made by tech art - they were just the "approved" vendor for the unit
anyway, the edge of the poly unit is what the problem is - this is a design problem for a lowered car - this one has no edge - it wraps around and under and replaces the front apron with an integral unit - it just skates over the top of things, rather than grabbing and curling
in a perfect world, this would be poly, but still the same design
the factory unit required the front apron to remain, leaving the splitter like a little "shelf" that sat over the black plastic and really was a mess to look at - i always hated it - it gave the car a dated look - the black apron beneath drove me nuts - mismatched body trim colors tend to do that - i suppose i should have taken a before and after shot to show the improvement - this one looks like part of the car now, and much more updated like all the new cars
yes, i am without that apron now - as i said, this unit has one built in - it's really a much cleaner design, and more importantly, should keep me out of the paint shop
no worries though - it is my car after all, and that's all that really matters - it's not like these are available anyway
Sure as with any car there are parts made outside the factory. The Poly/U unit has a Porsche P/N, that's close enough for me. Interesting trivia tid-bit, I didn't know they're produced by TechArt...
The lowering/clearance issue is why i've been hesitant to change my springs. However the handling is becoming more important and I'll have to cross that bridge at some point.
Tech Art made the "factory" rear spoiler as well.
Flash,
The front splitter looks great! I understand the desire to sculpt your car into the vision you desire. It can be a true love/hate relationship. I find many things on the 968 interesting. So, this is just another one of those things. I also liked the fact that you removed the center divider in the front air dam. It makes the front look much cleaner. nice work. ;-)
thanks - sculpting is a very appropriate term - i feel a bit like michelangelo with this car - to paraphrase him, the sculpture is hiding beneath - you just have to remove the unwanted bits
Hey, Flash, that's a pretty nice looking car. Is that some new model of Porsche? <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
roflmao - it is getting that way, isn't it?
looking forward to having you see it up close and personal in hershey
The way my car is currently looking, putting yours next to mine will be reminiscent of a car that I missed buying in Florida when I was looking. The owner decided not to sell when he saw Peter Olliviere's cab, with the comment: "You mean my car could look like that?"
I don't know if Peter is still around - anyone?
Hey Flash - are you selling your old 'motorsports' splitter? Mine was KIA at the track this weekend.
Great work, both of you.
jim - with this latest item, it's getting closer to my "vision", though to really get there involves some significant body line changes - won't happen on this one though
eric - yeah, but it's already spoken for - sorry
chris - thanks
Just did my requisite thread research. Flash, your splitter development efforts look about as accomplished as all your others. Well, a little over 3 years later, what are the alternatives for an attractive and functional splitter?
Anyone?
Thanks in advance?
Paul
Since I totaled my Motorsport spitter this winter I have considered having one made by Crawford Composites (Daytona Prototype builder) out of carbon fiber. I would use the damaged splitter as a model. It probably wouldn't have the curved front but would be flat with a rounded front edge and would blend in a the ends as the motorosport splitter does. No idea of the cost right now but will keep everyone informed.
i haven't given any real thought to reproducing mine, as it would mean removing it for whatever period to get it done - i do need to repaint it though, so perhaps after the season is over - who knows? i know i could get it done, and i know the price would be about $350 if i did 10 of them
Last Post by Cloud9...68
07-27-2011, 05:58 PM
Last Post by Lim Yong
07-20-2011, 01:32 PM
