CAB ROLL BAR
never ever remodel while you live there - it will throw your entire life out of synch, and leave you constantly asking "where did the day go?"
i am off to check a new place for the strap material today
What is the status of another run?
I might add my name to the list (pending spousal approval)
a couple short - there is another thread about that, with details and instructions
I finally found a free weekend day to do the install...the bar had some scratches and a visible bend (paint was cracked - that kind of bend) along the front steel angle that goes along the doorwell. I carefully got that back to being straight like the other side, and proceeded. Upon arrival, I also didn't have wood on mine..just the paper and some bubble wrap, which is why some of the scratches and bends likely came about, but no worries - all can be fixed.
My car must have been tweaked, or somehow slightly different in dimension (first batch of cars? mine's an early 92) , as the bar was a bit more involved in getting it installed. The deck box wasn't an issue, but the brace and mount points were off enough that pushing/shoving/sitting on it, just didn't get it aligned enough to start the bolts. After getting the driver rear and shoulder anchor bolts started, I proceeded to the passenger side rear bolt...this required a major effort to get the mount point in alignment, but it eventually gave in. Eventually I had everything started except the passenger lap belt anchor...left the most accessible and bendable part for last, figuring I had it done. I had a buddy apply downward pressure, and got it nearly aligned (it was off approx 1'' to begin)...used a screwdriver to try and pry it the rest of the way, but apparently that didn't quite cut it...the bolt just didn't want to thread, and eventually the threads couldn't take the abuse any longer and stripped. So, I'll be stopping by Sears for a tap and die kit, and hopefully a large clamp that will align the last mount point so I can re-thread and finally get it 100% installed. I'll also pick up the spray paint, and a new 1.5" bolt.
I'd recommend you verify the mount points first, getting the brace aligned ( and slightly bending where required) first, and then installing. Also, start with the rear mount points, as they are least accessible (if you're re-installing the deck box). should eliminate any issues like I had.
Also, make sure you've got a helper handy, as they can help force the alignment enough to start the bolts correctly, and a 4" screw clamp will assist with the alignment of the shoulder anchors.
The bar/brace really is a great design...as mentioned in earlier posts, it's a perfect fit with the top, and at least for me, it'll pass the yardstick rule for DE events with the helmet on. Flash, great job...one of us had to have a few problems with the geometry, but that's the thing with the older P cars...each a little unique.
NUTS!!! i am really getting unnerved by greyhound
clearly this thing got hammered in shipping - this has really been bothering me, and i am going to have to do something about this myself to prevent it from happening again
anybody else who has this happen, STOP! take pictures and file a claim with greyhound immediately - we insured it for up to $300 (that was their maximum), so this should cover any repair work that has to be done
by the way Orchard Supply Hardware brand Satin Black spray paint is a dead on match for the color of the powder coat
p.s. - the tap you will need is 7/16-20 - that's right - SAE threads there
also, do not tighten anything until all are started
start them in this order:
forward lower ones first
then upper shoulder harness ones
then rear legs
do NOT do one side of the car and then the other
torque in same sequence
another thought to anyone getting one of these - prior to installation, set it on the ground and check for symmetry - if the legs don't lay down the same, one of them is bent and needs to be straightened before attempting installation
Hi,
Just wanted to update the thread - got the brace/bar installed after some delicate re-threading, and a new bolt. Mine took a little coaxing to get lined up, and I found that for mine, the process was a little easier in ending with the shoulder anchor. But then again, mine was likely bent in shipping, and this is something you absolutely should check out first. Place it on a flat surface and make sure it's laying flat, as mine rocked ever so slightly, but it was enough to certainly cause frustration in installation.
Anyway, the brace is in the car now, looks great, clears the top perfectly, and REALLY makes a difference in the stiffness of the chassis. I went over some very familiar corners and off camber twisties again yesterday, first time with the brace, and I could feel a marked difference. Can't recommend this mod enough - Flash really did a great job thinking of all the little details (more than you might realize)that make this a great mod.
04-23-2011, 10:24 AM
02-27-2010, 02:58 PM
02-12-2010, 01:47 PM
03-17-2009, 11:31 AM
04-18-2008, 11:20 PM
Last Post by odb812
11-23-2006, 10:27 PM
06-12-2006, 10:13 PM
