Forum
Last Post
Strut Tower Braces, Chassis Braces, Suspension Braces, Roll Bars, everything you need to stiffen up your chassis.
Big Reds, Big Blacks, Pads, Rotors, Bias Valves, and all those things that keep you from bashing into things.
Get all the info on the different chips, who has what, what does what, and everything you ever wanted to know about chips.
Headers, Cat-Backs, Mufflers, and Tips - Find out where what is out there, what others are using, what works and what doesn't.
Looking to save weight on your 968? Have you found a new way?
All things transmission. Alternative gear sets, ring and pinions, shifters, CV joints, axles, transmission swaps, etc.
Got the "Mod" bug? Want your 968 to go faster?
This is where you can find out how to make your 968 corner like it was on rails.
Rear Wheel Spacers?
by ds968 | 08-26-2021, 04:31 PM
Intake Mods, ITBs, V8 swaps, Superchargers, Turbochargers, Nitrous, Water Injection, and everything else out there that would really make your 968 a rocket.
Looking to learn about that Lightweight flywheel, Power Pulley, Fuel Pressure Regulator, or Performance Cam?
Do you have some dyno charts to share? Have some G-tech data?
Need to learn about Limited Slips? Want to know the difference between the different types?
