Back to topic, regarding blanking off the extra port on the brake MC ..... need torque suggestions ..... and others may well need this in the future ....
The bleed nipple I ordered has gone AWOL in the post, so I've decided to use an M10x1 blanking plug instead and to keep the bleed nipple (if it ever arrives) as a spare for "whenever". I have an unused M10 copper "squash washer" so should be able to create a good seal.
With a bleed nipple the standard approach is "nip tight" and then one flat more to securely push the holes onto the tapered base of the hole. Should I take the same approach with the blanking plug, where that extra flat squashes the copper washer, or is there some sort of standard torque for M10x1 into aluminium??
I have the old MC so I can practice torque settings with an ordinary washer, and I can use the torque settings for the M10 head bolts as a guide, but I'm hoping someone has a definitive number because that extra "flat turn" is for a steel nipple into a steel caliper, and not for a steel nut into the body of the MC ..... torque settings anyone?
