02-19-2021, 01:10 AM
Help needed......
I ordered a brake MC(94435501110) which I thought was (is?) for my 968 only to find it is for all 944s post 1987 except turbo and not 968s.
When I took it out of the box it had an extra port in it, which surprised me as I thought it was just a stock photo. Then I thought it was maybe the extra port was an alternative to accommodate LHD and RHD.
Searching again I found a different MC (95135501101) which is for all 944s post 1987 including turbo and 968s .....same photo! Grrrrrr
How does that work ..... both MCs cover the same range of 944s .... post 1987 (excluding turbo and 968s)?? Which are vehicles with different MC layouts.
Both are Ate stamped.
I understand the bore of 944 pre 1987 was smaller and hence would transfer less pressure..... but in this case 94435501110 has the larger bore and the external layout of both seems identical except for the extra port.... which is opposite my front brake pipe and must be working off the same internal chamber.
Do I solve this problem with a blanking stopper for the unused port?? Part number anyone?? Anyone know if the bore and depth of those ports is the same as the brake nipples?
Thanks in advance
Oh, and the site I usually use had discontinued the 951xxx so this information could be useful for others in the future.
Thanks in advance
(This post was last modified: 02-19-2021, 05:37 AM by Roboman.)
![[Image: IMG_0885.jpg]](https://porsche968.s3.eu-west-2.amazonaws.com/Other/IMG_0885.jpg)
![[Image: IMG_0886.jpg]](https://porsche968.s3.eu-west-2.amazonaws.com/Other/IMG_0886.jpg)
![[Image: IMG_0888.jpg]](https://porsche968.s3.eu-west-2.amazonaws.com/Other/IMG_0888.jpg)
![[Image: backupbattery.jpg]](https://porsche968.s3.eu-west-2.amazonaws.com/Other/backupbattery.jpg)
.... I decided to get those stainless brake lines in order to head off possible splits given the new MC pressure.
