did the air box mod
well last night after readong everything on the air box mod i finally decided to do it. cut them out perfectly, sanded the rough edges down, made everything clean and nice. then jumped in the car for a quick test drive. i notice a difference, but what i notice more is the sound! it sounds great. mo im just waiting to get my full rsbarn exhaust!
Off to a great start, and welcome!
How about posting a pic or 2 of the car?
Get yourself some subwoofer ports to add into the holes and it should do even better.
and make sure they are curved, and not square edged - the right ones work well - the wrong ones not so much - running without creates a lot of turbulence
the bottom line is how much gain you see depends more on smoothness of flow than was thought - we never tested anything other than with the curved ports, so didn't know until recent tests showed up
it turns out they make more of a difference in smoothing the airflow than previously thought - i am working on determining what else can be done to further that right now - next is velocity stacks and a mod to the big mouth
Flash,
Can you send me the link the stacks you have selected?
I have found a few priced under $200 that "look great".
you probably found the same place i did - will finally have a chance to do the math to determine the length tomorrow
ya im going to order some of the subwoofer ports tonight. when i get home this afternoon ill throw some pics up! with the subwoofer ports ill get even better performance? along with it looking even better! sounds good i cant wait till i get them.
if you look at the 2" diameter port tubes on crutchfield and parts express you can see examples of right and wrong styles - crutchfield is right - parts express is wrong
right:
http://www.crutchfield.com/App/Product/Ite...701&tp=1559
wrong:
http://www.partsexpress.com/pe/showdetl.cf...tnumber=260-322
So, if I stick fans in them port tubes I can have a cheap supercharger? <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
I think the cooling fans from my old PC might fit.
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
ya i already purchased the crutchfield ones. just gotta wait for them to get here!
[quote name='Georges' post='48210' date='Feb 26 2008, 12:55 PM']So, if I stick fans in them port tubes I can have a cheap supercharger? <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
I think the cooling fans from my old PC might fit.[/quote]
Ohhh!!! I even have the larger 120mm fans vs the standard 80mm! If only it was that easy!
'93 968 coupe Black/Grey, 6 speed, 17" Factory C2 Turbo Wheels, Griemann Grills, and more once funds allow.
Just stick one of those tornado things in. BIG PERFORMANCE INCREASE!!!
[quote name='smokiemon968' post='48215' date='Feb 26 2008, 10:53 AM']Just stick one of those tornado things in. BIG PERFORMANCE INCREASE!!![/quote]
More details please, or are you just pulling my PC leg?
Brian
one born every minute
[quote name='smokiemon968' post='48215' date='Feb 26 2008, 01:53 PM']Just stick one of those tornado things in. BIG PERFORMANCE INCREASE!!![/quote]
That's an idea. Each port and each side of the port?
Seriously, though, I thought the subwoofer ports were for looks only and had decided to save on some weight. So now I'm waiting to hear about the length.
LWFW + Chip
Southboro, MA
You can see the length of the ports in this doc..
http://www.968engineering.com/pdfs/968%20a...difications.pdf
Thanks Banditsc. It looks like 75 mm or perhaps 1 cm.
Why do I feel gullible all the sudden? <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" /> Well, the original snorkel did have that plastic part in it. I'd expect the air filter itself would damp out turbulence. Now, if you tell me it keeps the walls of the box from vibrating... I'll see if the tech guys start laughing at my car.
LWFW + Chip
Southboro, MA
not 75mm - .75"
the turbulence is real - air entering the airbox is upset by the flat surface - the curved surface of the correct port, or better yet a velocity stack, facilitates better intake - the reduced gain from the turbulence is measurable
y i was wondering about the length for the subwoofer ports. but just cut them to .75" and i should be good? i was wondering if anybody had done any messing around with a ram like air intake system? also are there any other fun little mods out there to do?
yes, because they are not fluted, short is better - the idea is not to have them protruding very far into the box
velocity stacks just take this one step farther
yes, i have created a ram system - it works well - i had to delete the front bumper though to really make it work well - the key to a ram system working well is that the entry needs to be bigger than the exit
also, the airbox mod works better if you have the engine bay trim
Last Post by Bulti
11-03-2014, 02:49 PM
08-12-2008, 10:34 AM
05-26-2008, 04:30 PM
Last Post by Etnier
08-18-2006, 09:33 PM
Last Post by barth7
05-19-2006, 11:47 AM
05-09-2006, 08:38 PM
