did the air box mod
#41
I think he is saying the id of the pvc pipe is less than the speaker port.
lol - i was responding to rhudeboye
Hey Renalicious -- glad someone else out there vandalizes toilets. Being cheap and having a Porsche is poor combination. Still costs less than $4. Mine are white PVC but I figure they'll be black when I put the engine trim back and close the hood.
At this stage I don't think I'll have the patience for intense grinding worth additional point something HP. I'll probably wax the spark plug wires instead and make them more slippery. Another strategy is to lose some weight, I figure every 10 lb is worth about 1 hp. I have a lot of HP gain to achieve right here +3-4HP possible at low cost <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
So, anyone thought of buying toy trumpets and grinding them down? <img src="/forum/images/smilies/968/wacko.gif" class="smilie" alt="" />
As always, great discussion.
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
[quote name='Georges' post='48407' date='Feb 28 2008, 04:01 PM']So, anyone thought of buying toy trumpets and grinding them down? <img src="/forum/images/smilies/968/wacko.gif" class="smilie" alt="" />[/quote]
LOL!
-Ren
ok, so how long should the speaker ports be? I have the correct ports but fitted them flush with the inner wall of the airbox. At first I fitted them as described in the "test report"in 9magazine, I found out that the K&N filter only had the dark spot in the center....so I took a saw and shortened them, I also removed the little plastic piece that sits in the "snorkel"entrance. It seems to work, the filter is using more of its surface i.e. there a more darker spots on the filter, any thoughts?
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
more filter surface used is better - the intake restriction is zero with 3/4", but if shortening them spreads out the dispersion, while it won't increase power, the filter will go longer between cleanings, potentially maintaining the gains longer
Interesting. I added the Home Depot Velocity Stacks (HDVS) and it has changed the sound; I can't say I hear the air box any more. The only definite conclusion is that is spent more on the gas enjoying the car today than for the velocity stack. The 968 always impresses me when it first comes out in the spring. Every year I remember "hey, this is a really nice car!". It might just be a placebo effect, but it does seem to be smoother and better throttle response with the HDVS . Chip and air box; damn, third gear and squeeze the pedal to the metail, let the revs go into the red and the car keeps pulling without hesitation and wants more.
LWFW goes in two weeks from now. Help me, I'm getting the mod disease <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> and I've seen what it can do. The car was 100% stock before last year! The suspension has been feeling too soft lately. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
LWFW + Chip
Southboro, MA
as long as you're having fun
[quote name='Georges' post='48576' date='Mar 2 2008, 04:39 PM']LWFW goes in two weeks from now. Help me, I'm getting the mod disease <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> and I've seen what it can do. The car was 100% stock before last year! The suspension has been feeling too soft lately. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />[/quote]
There is no return. You may need to check in at your nearset loonie bin.
Or show the wife your receipts. I am sure she well put a stop to it.....
FYI...
4 Ports delivered from Crutchfield to my door $27.86...now where’s that hole saw
[color="#330099"]SpeedRacer64[/color]
[color="#000"]100%[/color] Pure Stock 1994 968 [color="#000000"]Blk/Blk [/color] [color="#CC0000"]6Sp[/color]
which ones did you get, the 2 inch ones? and your just going to trim down the length? im about to order the same ones!!!
The ones recommended earlier in this thread
http://www.crutchfield.com/App/Product/I...01&tp=1559
They look the job...
Good Luck
LuKe
[quote name='Georges' post='48576' date='Mar 2 2008, 03:39 PM']LWFW goes in two weeks from now. Help me, I'm getting the mod disease <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> and I've seen what it can do. The car was 100% stock before last year! The suspension has been feeling too soft lately. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />[/quote]
Are you getting the RS Barn with the spring-centered clutch disk that Flash developed? Definitely let us know how it turns out.
This is on my wish list, but unfortunately, I learned to heal-and-toe at a Bondurant high perfromance driving class 28 years ago, and have been double-clutching ever since. So, I'm afraid my clutch and flywheel will last forever. Must....force.....myself.....to.....slam....into....lower....gear....and....pop.
...clutch
luke-
the link is working <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> i think i know which ones you are talking about tho
[quote name='Cloud9...68' post='48609' date='Mar 2 2008, 11:52 PM']Are you getting the RS Barn with the spring-centered clutch disk that Flash developed? Definitely let us know how it turns out.[/quote]
Yes, and driving 500 miles (round trip) to get it done. AND, leaving at 6 AM. I gotta be nuts to travel that far. <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> My wife has been strangely silent about all this <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
I indeed will report.
Wish me luck. This is very high risk. What will happen once I step into the candy store? <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
P.S. 100K on the original clutch and heal-toe at every opportunity. Maybe I should wait??
LWFW + Chip
Southboro, MA
lol - don't feel bad - i'm dragging the car 2800 miles each way to get a belt job
of course, while i'm there, i'll probably have a new head slapped on and then pop in to the event at hershey
[quote name='flash' post='48657' date='Mar 4 2008, 08:52 AM']i'll probably have a new head slapped on[/quote]
That's my fear about the candy store. <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> You're my reminder of what happens when you fall to the dark side. If I don't behave I'll get my head slapped when I get home.
LWFW + Chip
Southboro, MA
The candy store is only a click away...
http://www.rsbarn.com/
[quote name='smokiemon968' post='48671' date='Mar 4 2008, 09:46 AM']The candy store is only a click away...
http://www.rsbarn.com/[/quote]
I Second that. Ordered with my chip the SS clutch line as well.
[color="#0000FF"]Brian[/color]
[color="#4169E1"]My Collection:
94 968 Midnight Blue
95 Audi S6 Avant (Seattle)
93 VW Corrado SLC
91 Audi 200 TQ Avant[/color]
unfortunately for the process, the logistics have gotten tougher, as i now need another car on which to test things - i've gone so far with mine that it is nearly impossible to get accurate results when talking about something like this
Based on what I have seen so far flash I'll offer up my cab for your experiments <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Last Post by Bulti
11-03-2014, 02:49 PM
08-12-2008, 10:34 AM
05-26-2008, 04:30 PM
Last Post by Etnier
08-18-2006, 09:33 PM
Last Post by barth7
05-19-2006, 11:47 AM
05-09-2006, 08:38 PM
