Threads: 27
Since joining the forum I have been intrigued by the airbox modification. I haven't tried it since I really don't want to look at the holes, honestly. But I would like to have the extra bit of horsepower and the sound. Someone in one of the MANY postings on this topic suggested that holes could be cut in the BOTTOM of the airbox instead of the front, perhaps as shown below (white poker chips in possible hole locations). This location would take advantage of the space between the radiator and the bottom of the box. My thought was this: cut the holes there, and leave the snorkel on to bring in cooler air to mix with the additional warmer air coming from underneath. The box still looks like new, but might you also get (some of) the extra horsepower and the sound? And what impact would the radiator have on it?
Has anybody tried this? Sorry if someone did and already posted the result; there were a LOT of threads related to the airbox mod that I searched through. Seems there is always interest in this topic!
Threads: 27
Flash, I understand your point about the temperature of the air by the radiator. But are you saying that the temperature of the air introduced through the snorkel in the normal configuration is warmer than the air in the engine compartment at the front of the airbox?
Threads: 27
Thanks, this is very interesting. I would never have guessed the difference in temps at those intake locations. I'm definitely going to take a closer look. Being an engineer, I can't seem to stop thinking about how the airbox mod could be accomplished without being so darn...sorry...ugly. For instance, could a molded insert be designed that would include optimized openings (size and shape), which could be easily removed after the autocross without hauling around an airbox....hmmm.....
Threads: 19
[quote name='astroede' timestamp='1346901873' post='132221']
You could pickup the trim that the 92 has in that area. With it you don't see the front of the airbox
'92 Midnight Blue 968 Coupe
Threads: 22
You can still buy them new, IIRC. Also, there's a post on another site where Jeff (the seer of all factory 968 options) mentions that most cars up to 94.5 came with the front cover. Something like 1800 of 2200 North American coupes came with them. I wonder where they all went?
-Matt
Threads: 14
I have one in my 1993, but my 1994 didn't have it. I like it, and it makes a nice seal for the cool air coming in from the outside... Pete makes a pretty cool aluminum box that works much the same as well. Saw it on one of the cars he and Max put together.
Joel Wahlsten
Threads: 27
Further to Judge's question, if you remove the snorkel, should you block the piece left in the bumper area or leave it open, given that the air coming in is significantly warmer than the nearly ambient air you are now pulling in the airbox holes? Would the airbox then be pulling in much warmer air from hot areas in the engine compartment for lack of a supply from the snorkel piece? Arrrrrgh...you know what I mean...what setup will get you the coldest air going into the airbox?
Threads: 15
I'm thinking the throttle-body heater-feature would negate any air temp advantage of the airbox mod. What do I use to do the by-pass - anyone got a pic?
-Austin
'94 Black/Tan Coupe
