Threads: 5
Flash,
Testing would be expensive, I doubt $25K but expensive. The question is whether or not it could be accomplished at a reasonable added cost per roll bar.
A broken or otherwise damaged Cab should be able to be acquired for <$10K and possibly <$5K. Then the question is how to test it. Dropping from a crane might be a good test. There are lots of possibilities of how the test could be carried out, unfortunately one car probably means one test.
WIth all your TV connections could you get a TV show on roll bar testing, or get a 968 used for a stunt with the bar installed?
Hopefully none of us will ever find out what happens when your roll bar hits the road!
I am still looking forward to the opportunity to complete my purchase.
Threads: 5
Quote:we all know that you compete the car - knowing that, i would not recommend the DE bar for you, and would not, in good conscience be able to sell it to you - i would insist that you purchase the race bar
Perhaps I am being punished for suggesting the bar could be tested?
As I have said many times before I look forward to purchasing the roll bar. I hope to choose the exact specs based on what most fits my needs.
Threads: 5
Flash,
My questions about testing the roll bar are nothing more than wondering if it could be tested. I have not made a single derogative comment about your roll bar design?
Threads: 5
I was in, until I got kicked out <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Flash you have my email, and I am still hoping to have one of these, probably the DE version soon.
Threads: 5
Since it is a topic that I am unfamiliar with I ran a google search for "roll bar testing" found these two links in the first page of search results;
http://www.teammiata.com/mall/Boss_Frog_Roll_Bar.asp
Quote:And speaking of no compromising, to ensure that the bar would be up to protecting us and our loved ones as well as you and yours, a destructive test with the roll bar installed in a Miata was conducted (scratch one Miata!). Following the intent of both SCCA and FIA guidelines during the test, three simultaneous loads, 7.5G vertical, 5.5G front, and 1.5G side, were applied with a combined load of over 13 tons. The roll bar passed the destructive test with flying colors. The roll bar stayed completely intact, with nearly zero deflection. The car body bent right behind the door jamb, but the roll bar and cockpit area was perfect. A registered engineer witnessed the test, and has issued a report of his findings. In short he concluded that the Boss Frog Double Hoop Roll Bar meets the intent of both SCCA and FIA specifications.
and
http://www.ist.org.uk/anti_roll_bar.htm
Quote:IST 's anti-roll bar fatigue testing machine is used for the sample testing of production batches to test the end result of your design, manufacturing and quality control processes. It can also be used to predict the performance of any new developments e.g. design changes or manufacturing changes.
* I searched for this information purely for my own education and post here only to share the information without any intent to criticize the Flash designed roll bar which do intend to purchase with or without testing.
