Threads: 8
The factory shop manual says the order doesn't matter. So apparently, Dr. Porsche is not emotional about it.
That said, I like to bleed the inboard side first, outboard next... furthest caliper going down to nearest... then do the clutch slave.
My logic is to bring new fluid in from the brake line, completely replace it
UP TO the point in the caliper where it continues on to the outboard side.
'Course, when I have one side of the car in the air at the track, wheels off... all that goes out the window and I bleed what I can reach right there and then.
Truly, as long as you pull enough fluid from each to accomplish your goal (bleed caliper and/or bleed caliper and entire line back to reservoir), it doesn't seem to matter.
Also, do get in the habit of using the right torque to close the bleed screws. It's quite low and is an opportunity to mangle nice aluminum threads.
HWFM Chief Marriage Counselor
Threads: 8
[quote name='Miles'PHTurbo968' post='27990' date='Nov 16 2006, 01:32 PM']looks like it goes to the clutch master or slave cylinder[/quote]
When you go to bleed the clutch slave, I recommend removing the negative terminal at the battery first. That little 7mm wrench likes to find the hot side of the starter while you're poking around down there.
Ask me how I know <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Threads: 8
Glad to hear it. My son was bleeding the brakes on my old 944 when he was 10. Motive is the hot set-up.
Threads: 8
[quote name='flash' post='28165' date='Nov 21 2006, 10:03 AM']i just bled mine a few weeks ago, wheni installed the 5/33 bias valve[/quote]
Flash - I've "heard" one needs to bleed the ABS unit if you open it up and lose pressure (like you do when you change the brake proportioning valve). Something about it having a little reservoir of its own and needing to be purged of any potential air.
I did so by waiting for a rainy day and going out to light up the ABS like crazy. Subesquent little bleed and it's all done.
Just my 2 cents on that FWIW.
