Located and purchased a complete air box on ebay.co.uk.  Unfortunately the vendor wouldn't ship to France so I've used my "at risk" brother as a mail drop.  It means I won't actually get it until this mess is resolved, but no matter as I have plenty of other jobs to keep me busy.  Very happy, good start to the week!
started to  do timing belt  job and found that  i will have to fix  cam sprocket cover first
also, is it possible to have oil leak from hydraulic tensioner ?
[Image: 93421145_656323265192366_115712732985661...e=5EC3606D]
1992 968 Targa with M030+M220
1989 951 M030 M220
If in doubt, FLAT OUT .
Yes it is possible as they are oil damped inside, I do not think its possible to repair them
944-105-172-03 $126 but pet also says, dropped on the 1st of December 2019, without replacement, if you need a new one get in quick before they are NLA
That will need a helicoil insert, at least its easy to get at
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Quote:That will need a helicoil insert, at least its easy to get at
i will get  that whole piece machined off and  will put some  alluminium or stainless adapter  there to last forever, will not pay 400+ eur for a piece of alluminium. still, i dont plan to use distributor  in future but now i need that fixed properly
1989 951 M030 M220
Helicoil thread replacement, about $40 should be as good as new
Mine has been helicoiled for about 10 years. No problems.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
yes guys, threads can be repaired but i miss some material which supports the front cover, which means  my distributor  is not aligned properly  and so on. i will not risk brittle magnesium from that  part to fall into my timing belt space,  will post photos of the  repair
1989 951 M030 M220
I have spent 3 hours today repairing a water damaged Motronic ECU, it had one pin completely missing, bit of a pain as it was in row 3, right at the bottoms.
all done put it in the car just on the lead not bolted in, works fine, save a fellow 968 owner $1600
Found out i miss check valve in my variocam. Probably fell out at last service before i owned the car. That little thing is freaking expensive. I hope some member has a spare, maybe ?
1989 951 M030 M220
Tiny touch up painting in hard to see and reach areas.  Hey, what else you going to do during this corona lockdown?!?
Check Valve 944 105 508 00, €106,33 at first search.
It's not cheap, but still possible to buy.
i ordered it with tears in my eyes Big Grin
1989 951 M030 M220
This week- 17 rims Cup1 design. I used to drive 16 before and thats a huge difference, love it.
It was a busy week for my 968.
New timing and balance shaft belts. I went with the Gates racing belt, I expect it to last a long time. New rollers and water pump, motor mounts, and drive belts.
But, best of all, he found the problem with the air bag light. Bad connection on the clockspring, fixed it and reset it.
The icing on the cake was he found a crack in the sending unit in the gas tank. Sealed it up and the gas smell has greatly diminished.
Now the driving begins, once this quarantine lifts.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Wow thats a result, that airbag light has been driving you nuts
The sending unit was a source of your gas smell?
Yes, that light has been source of frustration for 2 years. It's been great seeing that light go off when I start her up.
As for the fuel smell, I am not going to count my chickens just yet. The mechanic I go to here in Reno trained here when he was first starting off and Porsche was located in Reno. He worked in the Bay area for 30 + years then moved back here and opened a small shop when he retired. One of his friends from corporate recently retired and also relocated to Reno. He asked him about the gas smell in my car, and his friends response was that many of the early 968s had stress cracks in the gas tanks and vapors would seep out of the cracks into the trunk space. We will examine that possibility if this latest solution does not work. The crack in the sending unit was located around one of the nipples that attach to the rubber hoses.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
I made little spring service, changed motor oil & filter, also changed brake fluid. Its very nice driving again after winter.
Thought tank cracks were a 924 thing with the steel tanks, not heard of cracks in the plastic tanks
I know they are a problem in the 924 and 944 because the tanks are steel and thrashing the car around causes the fuel to shift, which flexes the tank resulting in eventual cracking. As for the 968 tanks, I am taking his word for it since he works for the company.
On a happier note, the smell has diminished substantially. Still noticeable on hard left turns, so no NASCAR for me. I may be looking at a couple of problems.
Put some miles on her this weekend. The Gates race belt with a Conti balance belt seems to be the hot ticket. The Conti belt is a lot quieter than the Gates balance shaft belt was. Not sure why, but the difference is pretty noticeable.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Last Post by J.Elenbaas
02-15-2022, 05:25 PM
Last Post by Kim
06-22-2020, 02:14 PM
Last Post by az968
02-21-2016, 04:28 PM
12-25-2015, 03:33 PM
Users browsing this thread: 12 Guest(s)
