Threads: 13
It will go away after a properly heat up of the engine. Unlucky if you will replace the lifters- as I did see the post of it- with the audi lifters you must do the job again. But hey you are now heaving lots of experience I dd bet you can do it withon two hours.
Threads: 45
<p style="margin-left:40px;">it only slaps and scraps momentarily just before the your **cked light illuminates, you can get the engine codes once the car is at the indie having a 8k engine rebuild
Threads: 49
I have heard chains (specifically Nissan 4 cyl) make a slapping sound as they got loose and started sawing through the block, but if a belt does that I think the sound you hear is your wallet being slapped around by your mechanic. i
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 167
Generally, I do not change the water pump with each belt change. The only other thing that seems to be a no brainer is if the balance shaft seals are leaking (if they are not leaking don't touch them, or they will be).
JMHO,
Threads: 45
depending on the year of the 944.
our cars have a 78mm impellor so did some of the late 944's Turbo and S2, the early cars had a 68mm impellor
current part number is 944 106 021 24 @ £516.00 $658
there is a kit available.
that comes with...
Gasket
Round Seal?
Bolts
Washers
Nuts
Roll pin
Shim
Thermostat
Water Pump
and a few other bits
Part Number 944 106 021 AX (AX=Exchange) @ £432.00 = $551
that's basically everything in PET image 105-00 except 7,8,9
(This post was last modified: 12-06-2016, 07:45 AM by
Waylander.)
Threads: 45
When I did my belts year before last the water pump was dated 05/1992 no bearing play but a bit noisy at 139k miles
