Threads: 45
It normally lines up exactly on the lower, half tooth out at the top
It can cause so much vibration the oil pickup tube cracks, have you checked the gap between the idle wheel directly above in that picture, and the balance belt as it goes round the shaft pulley, it should be 0.5 mm, this is to stop the belt jumping a tooth
Threads: 45
Oh yes, here starts the while Im in there!!!
Threads: 45
both those jobs are the hardest on the car,
front crossmember has to come off for the pan gasket, and you really will find it easier to change the gasket and leaking internal o rings in the oil filter housing while the cross member is out the way
I have had to get the oil filter housing skimmed flat on two cars so far, Oh and the exhaust heatshield is held on by the top two bolts of the housing, you need elastic man to reach them
Threads: 45
(This post was last modified: 03-08-2021, 08:48 PM by
Waylander.)
Threads: 49
I just brought mine in for the follow up after the belts replacement. It had a buzzing vibration at 3850-4250, which turned out to be a balance shaft off by one tooth.
All fixed, back to smooth and quiet power! Amazing how much difference a single tooth made to the overall feel of the car.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
