Go to the Search menu, which is near the upper right part of the screen, and do a search on belt replacement. There are several very detailed threads on this topic, including a step-by-step DIY. I'm planning to do mine soon as well, so I've been doing some research on it myself. The job appears to be fairly straightforward, since there's no need to set the tension of the timing belt. It seems to be pretty much R & R, though there is a fairly large number of steps. Probably the most difficult part is finding a flywheel lock. They are pretty expensive (a little over $100, I think), so if you could find somebody in town who has one and would be willing to loan it to you, it could save you some money. Good luck.
