Oil Change?
Okay, call me an idiot. I bought my 968 last year, and after paying more than I wanted to for the last oil change, I decided I can do this myself. So, I bought some oil, and a filter, and a drain pan, etc. This morning, I got under the car and could not find the drain plug.
What do I need to do to change the oil? Do I need to take off the skid plate?
This may seem really basic, but if someone could take me through step-by-step (and maybe show me a picture of the undercarriage indicating the location of the plug), that would be great.
Thank you!
You have to remove the second pan from the front right behind the "batwing." The oil sump is approx 14" x 10" or so and is ribbed, with a smooth circle in the center....it is on the bottom of the motor just behind the crossmember. The drain is on the side of the sump (passenger ?) and is ~17mm IIRC. Not around my car and can't describe it much better. Good luck.
[quote name='rustech' post='38271' date='Jul 14 2007, 02:23 PM']You have to remove the second pan from the front right behind the "batwing." The oil sump is approx 14" x 10" or so and is ribbed, with a smooth circle in the center....it is on the bottom of the motor just behind the crossmember. The drain is on the side of the sump (passenger ?) and is ~17mm IIRC. Not around my car and can't describe it much better. Good luck.[/quote]
Wow! w/ such great details who needs a pic.
My first oil change on the 68 was just as confusing. I was so use to the Japanese cars so i would look for a square slanted pan, sitting over to one side of the car, with the obvious 14mm drain plug.
The 68 was so different (and so centered) that I didn't know what I was looking for.
[quote name='rustech' post='38271' date='Jul 14 2007, 04:23 PM']You have to remove the second pan from the front right behind the "batwing." The oil sump is approx 14" x 10" or so and is ribbed, with a smooth circle in the center....it is on the bottom of the motor just behind the crossmember. The drain is on the side of the sump (passenger ?) and is ~17mm IIRC. Not around my car and can't describe it much better. Good luck.[/quote]
Thanks for the fantastic description! I was on the right track yesterday, but I didn't want to take off a bunch of panels and find out I'd done the wrong thing.
Boy, was it hard to get the oil filter off and on. I disconnected the electrical lead to what I assume was the distributor. Then, there was a hose about 1" thick which made it very hard to get the filter off. It looks like it was leading to the air filter; is it okay to remove this hose?
My oil filter wrench couldn't get a grip until I wrapped the filter in duct tape.
Anyway, I'm having a nice feeling of satisfaction at having done the work myself. I haven't bothered to change my own oil in almost 20 years, but it felt good to get under a car again.
good for you.
I dont have my 68 in the garage at the moment but I think that 1" hose you mentioned is a coolant line.
If you replace your filter w/ a K&N one you will not have such a difficult task removing it 3K miles down the road. They come with a socket fitting on top of the filter.
Last Post by unknown4u
12-17-2023, 08:16 AM
Last Post by J.Elenbaas
06-13-2020, 05:17 PM
02-20-2020, 08:48 AM
Last Post by MCL968
02-18-2020, 02:45 AM
07-29-2019, 02:08 PM
Last Post by az968
12-23-2016, 12:33 AM
03-20-2015, 07:14 PM
