Maybe the odometer/speedometer should have its own forum altogether...
Yes, I'm in the middle of my fix, and looking closely at my gears. They look fine. The 12 tooth is yellow, but not missing any teeth. I've given them some pushing, and none are even brittle...
As a check, when the gears are installed, I can't rotate the odometer dials, but with the stepper motor and the gears out, they spin freely. I think I need to look somewhere else. Note, the speedometer is out, also. (Looking at things, I think that the speedometer is simply an electomagnet powered from the two stepper motor wires that go between the main and trip odometer dials.)
You may realize that I took off the dial and faceplate before I understood that this is not necessary for the gear fix. (Also yes, I bent the pointer.) *However,* I think that this is a good way to see if it's a mechanical or electrical problem... If the odometer numbers spin with everything engaged, it's obviously the gears. If the odometer numbers don't spin... probably not the gears, right? For those who have had *both* odo and speedo go bad, perhaps it is the electrical contacts, or something else keeping the signal from making it to the stepper motor? The removal and reinstallation of the gauge would provide renewed contact, making it feel like the gears fixed the spedometer, even if it was just the reseating of the gauge.
It doesn't seem like there is any mechanical connection between the very mechnical action of the odometer after the stepper motor, and the speedometer. The speedometer seems to be completely electrical, and powered simply by the two wires coming off the stepper assembly.
Also, looking at my connectors, the four pins sticking out of the white plastic housing for the instruments, they are *white* with corrosion. I think cleaning the connections and perhaps a wipe with some dielectric grease may solve a problem that is right now, baffling me.
Any thoughts on this theory, and the latest update to the ultimate-of-all-968-strings would be appreciated.
Jim
