Threads: 12
I had the same problem and replacing the gaskets did the trick. I purchased mine from my local dealer. I don't recall the actual price (I purchased several things at once) but I think they were fairly cheap.
If you cut the rear (larger gasket) you won't have to completely remove the door handle. Make the cut on the bottom and it won't be noticable. It took me about 15 minutes.
Good Luck!!
Bart
'92 968 Arrest me red Coupe
'71 G-Production 510 #61
Threads: 147
[quote name='968gene' date='Feb 19 2005, 11:11 PM']My door handles are loose due to bad gaskets, Anyone know of the best source for a fix? Thanks in advance.
[right][post="993"]<{POST_SNAPBACK}>[/post][/right][/quote]
Gene check out the Screen shot you should find all of your part numbers there:
Base 944 537 631 00 Left
Base 944 537 632 00 Right
BASE SMALL 944 537 621 00 Left
BASE SMALL 944 537 622 00 Right
Sunset always has great prices.
http://www.sunsetimports.com/porscheatcost.php
Black 03' Turbo X50
Black 05' Denali
(This post was last modified: 02-20-2005, 03:57 PM by
SANDOVAL.)
Threads: 0
Bart, any tips on doing this?
I'm guessing that the screw on the trailing edge of the door holds the handle in place (#6 on Eric's screenshot). Is this right or did you have to take the door panels off?
1995 968 Sport, Iris Blue / Black
Threads: 0
[quote name='Anchorman' date='Feb 21 2005, 12:19 AM']If you want to replace the gaskets using the "cut the big one on the bottom" trick, you don't have to remove the door panel. Releasing the handle with the bolt that's in the door edge is all that's needed. While the handle is out of the door, I'd suggest doing everything you can to clean and lubricate the mechanism. These can be stubbornly difficult once they start binding up. As they say, "Don't ask me how I know".
[right][post="1023"]<{POST_SNAPBACK}>[/post][/right][/quote]
Excellent, seems pretty straightforward. thanks!
