05-11-2019, 03:39 AM
Ok. I've read the various write-ups on replacing the door handle gaskets. Even read the service manual section that covers the door handles. To say it's lacking some details is an understatement.
So far, I've put over 24 hours into just one side. It's absolutely maddening, even with the inner door panel removed.
I'm stuck at reattaching the locking mechanism to the lower ball joint. People say "reach up through the forced air vent hole with long pliers and PRESTO!" like it's some sort of magick.
I've tried pliers, several types of long hemostats, prayer, cursing, swearing, and banging my head on a log.
The lower part of the window frame is unbolted so it is moved. Slightly. The anti-theft shield is removed.
The closest I've come so far was by looping a piece of wire around the arm that the ball joint is on, and pulling the arm downwards, while pressing the door open lever to drop the locking arm down enough to barely touch it with my fingertip and maybe position it over the ball. But I'll be darned if I can apply enough pressure on it to pop it in. After all, it's the very tippy tip of my finger,
Even using a borescope to really see clearly, and pliers... nope, nosiree.
My neighbor's son is a surgeon. he tried it today and failed as well.
I've attacked it from every angle, and every hole I could fit a tool into.
Short of disassembling the entire window, what's the trick? Tiny people on the end of the pliers? The Force? Grease?
When the white connector kept falling down, I had to use a paperclip with a hook on the end in my mouth while my hands were doing things like holding the door handle steady and holding a screwdriver to pop it on, in order to retrieve it and finish that step.
I have never done anything so maddening.
Does anyone happen to have the #138 June 2005 Excellence mag which has the article about this?
(This post was last modified: 05-11-2019, 03:42 AM by WolfeMacleod.)
