I got it. There is a horizontal rod that the electric door lock shifts side to side. When unlocking, it is pushed towards the jamb. At the end of the rod is a plastic/nylon socket. It is attached to a ball on a lever arm attached to the lock mechanism. Push the lever towards the jamb, door unlocks. I could hear the rod move, but it wasn't unlocking the door.
The socket has completely broken on the driver's side and partially broken (pieces missing) on the passenger side. I was able to put the glass down and insert a flat aluminum bar to actuate the lever arm.
You can see these connectors with the glass down, so a visual inspection is possible. Time to pull the door cards, I hate doing that. I hope the glass doesn't have to come out to replace these small parts. Could I be that luck......probably not.
