09-23-2023, 03:25 PM
I'm trying to replace the left (US drivers side) door window outer seals on my 968 coupe - both lower, and "back" - see below picture for issue :
I had originally ordered part "PCG-853-371-B" thinking that looked correct based it looking like part 3 in this diagram:
Turns out that's NOT the seal, but rather the "moulding" - a metal trim piece. Oops.
So now I'm looking elsewhere in the parts catalog and online sources (pelican,etc) and think the correct part for the lower "window slot seal" is "PCG-837-469-A" (superceded part# 477 837 469 A) shown as part #2 in below image from PET.
I cannot seem to find the rear vertical seal in the parts catalog - the closest looks to maybe be "944-537-079-00" (part #4 above in PET) but that shows as a "window guide" around the top as well, while the damaged part on mine appears to be the vertical back part of the window ONLY.
Can anyone confirm or correct the "lower (horizontal) seal" part number and provide any insight for a part number on the "rear (vertical) seal" so I can get them ordered and replace the two damaged seals I show in the top two pictures in this message?
