08-14-2008, 01:56 AM
The driver's side rear view mirror has broken, only the glass. Actually the glass fell out of the mount, if it didn't break I would have glued it back in.
However the mount seems to be connected to the innards of the whole mechanism. And I can't quite figure out how to replace it. Here is a pic of the replacement part that Sunset sent. There is a ring on the back which rotates.
Here is a pic of the bottom end.
From a post from Bob Blackwell some time ago, the method of replacement is to insert a screwdriver into the hole at the bottom of the mirror housing to release the retaining ring that holds this thing in place. I found the same general instructions in the workshop manual. I guess I should rotate this ring using the little indentations, which appear to be made to insert a screwdriver. There also appears to be a locking pin.
So after getting out the circular saw to see what is inside the mirror housing (just kidding). Any suggestions? I tried to turn the retaining ring via the hole in the bottom of the housing, but very difficult to know how much pressure to apply, and if I got the locking pin undone. etc. Thanks.
Roland
Roland
