[quote name='Lim Yong' post='65010' date='Jan 3 2009, 05:28 PM']Hi all,
so will replacing the back calipers with the fronts calipers balance and improve the car's braking?[/quote]
I have fitted the standard fronts to the rear with no problems regarding mounting, just bolts straight on.. BUT...
Im running the M030 front callipers, with the "original fronts" on the back, the car is VERY unstable under heavy braking, especially in the wet. There is TOO much braking at the rear , so much so, that the rear locks up before the fronts...
It feels GREAT in the dry, but its a real handfull in the wet. It just wants to swap ends all the time, especially if you dont brake in a straight line.... <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
Ive yet to try it with Big Reds fitted to the front, And im waiting to see if Pete [RS barn] has any comment on this.???
Although i think ill be re-fitting the original rears back on soon...
[quote name='rob76turbo' post='65018' date='Jan 3 2009, 06:53 PM']Cloud...
I am thinking of adding the 944 brake ducts that Paragon sells and placing them behind the mesh below the bumper. I have not worked it out just yet and I am not sure I will actually use those ducts, but that is the general idea. I will then add those brake cooling brackets from Lindsey and the 3" tubing. I have to figure the best way to route everything, but I think that cooler brakes mean better performance. I am not doing a "Big Black" or "Big Red" update at this time and will use my current braking system. I need new rotors anyway (that is why I was asking about cross drilled vs solid). It seems the racers in the group say solid is the way to go....[/quote]
Im not sure youl be able to do this. AS the oil cooler will be in the way...
I had fitted a set of the fog light replacements to an old car i had. I eventually managed to route the ducting through to the brakes, but it was DIFFICULT , theres not much room behind the oil cooler / power steering area to route the ducting...VERY convoluted. + not sure if it actually did anything when fitted...
Ill be fitting the cooling /fog light replacements to my current car, but just blanking them off. Just a cosmetic mod... <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
