<!--quoteo(post=75076:date=Jul 7 2009, 06:28 PM:name=flash)-->QUOTE (flash @ Jul 7 2009, 06:28 PM)
<{POST_SNAPBACK}><!--quotec-->everybody knows i've been talking for some time now about making some aluminum hat 2 piece rotors for the car - well, i am now at the point where i am ready to do this, and am curious as to whether or not anybody else would be interested
because the primary intended use would be street, pad knock is a very real consideration, and consequently fully floating rotors are out of the question - they are great on the track, but make a racket on the street - these will not be fully floating - they would be two piece with aluminum hats, but bolted together
what i am contemplating is a 4 wheel kit, not a 2 wheel kit - i want to maintain brake balance
weight loss was the primary goal - the new rotors would be about 3 lbs less net each - that translates to an equivalent weight loss of nearly 50lbs in the car, and because it is rotational mass, this is something you immediately will feel off the line
they would be about 1.5" larger diameter, providing approximately 25% more braking
cooling would be improved since they would have more braking torque and therefore not get as hot to begin with
they would be identical thickness to stock - direct fit to pads and calipers
they would use the OEM calipers and pad size - that's right - no big heavy calipers - no big caliper cost - adaptor blocks would be provided to space the caliper outward - this is a VERY common practice
they would be slotted and/or drilled
installation would not take any longer than a normal full brake change - you would NOT need to disconnect the calipers from the brake lines (read as - no bleeding "required" though we would still recommend flushing at the time of changing)
the parking brake would still work - it would NOT be advised that it be used as an emergency brake, but then neither is the OEM one
these will NOT work on 16" wheels
as a reference point, big red FRONT ONLY kits are about $1700 - they also add about 6lbs each
due to the initial cost of the hats, estimating kit cost at about $2400 for ALL FOUR CORNERS - however, unless you trashed them, replacement rotors would use the same hats, so that cost would only be about $200 per rotor after that
interested?<!--QuoteEnd--><!--QuoteEEnd-->
I am very interested. When you say "will fit stock calipers", are you referring to M030-cars or the regular ones? I'm about to fit 928 S4 calipers (same as M030 in most aspects) and the minimum rotor thicknes is, I believe, around 30,5 mm. Hence a 28 mm rotor will be too thin. Will the hat be M030 or regular? A M030 rotor will fit a regular hub but not the other way around. Or will the hat be M030 and the rotor available in both 28 mm and 32 mm?
