Air conditioner problem
Hi all,
When I push the button for the air conditioner it makes a loud groaning type of sound for a couple seconds.
But then, it does not throw out cold air. Is that sound the compressor moaning because it is seized up.
Also, before this started happing, cold water was spitting out of the vent where cold air was suppose to be.
Please help, it is 96 degrees today.
Thanks in advance,
Anthony
Sounds like the AC drain hose is blocked up. 944 572 221 00. It is located behind the radio.
That hose was obliterated/ and also plugged.
This is a stupid question, but, How do I unplug it.
I guess I have to take it a part.
Is that the only way.
Thanks,
Anthony
Take it out of the chassis and mouth pipette it. Or you can just stick a screwdriver up there, be careful about the gush of water that will follow...
It's above the torque tube so it is very difficult to access from under the carriage.
Last Post by TonD
06-18-2012, 07:01 AM
Last Post by jeff968
07-17-2009, 10:05 AM
Last Post by banditsc
11-25-2008, 09:00 AM
Last Post by mick968
11-07-2008, 04:17 PM
