[quote name='Greimann' date='Mar 8 2006, 10:52 AM']I have done 3 belt jobs (on 3 different cars) without the tension tool and as far as I know, they are all still humming along, at least mine is (Gene, Doc?)
The tensioner takes care of the cam belt. No need to worry about that.
The balance belt can be done by feel with the twist method. Invariably if one does it by hand, you tend to set it "tight". That is a relative term because it is freaky loose when set properly. If you get some whine when it is dead cold, but it quiets down after a minute or two of driving, then it is OK. I like to think if it as an audio diagnostic of belt health.
My hunch is that because of the balance belt's tendency to whine when tight, Porsche spec'd the tension so carefully to make it quiet when cold, but still stay on the sprocket when warm. It would be hard to sell cars that shrieked like that right off the lot.
[right][post="17072"]<{POST_SNAPBACK}>[/post][/right][/quote]
I agree 100%, the tensioner takes care of the Timing belt, the balance shaft belt is very loose, if it's even a bit tight is will howl like hell. I played with this a couple of times, right after I bought the car I did the belts and rollers, shortly after I pulled the head, rings etc. and put the balance shaft on loose and it worked out fine. Nice and quite. No gauge.
