Sorry to answer my own post and bore the experts here, but Im adding a couple of pics to document this procedure as I didnt find it described properly anywhere. Thanks to michaelmount123 on Rennlist for describing cylinder head measurement on the Porsche 968 or 944 S2 head for me.
Procedure:
Use the machined flat in front of and above exhaust port 1, NOT the one behind port 4
Measure accross the head at this point using a vernier.
Measure the depth from the top of head to the flat using a depth micrometer and subtract to get the head thickness.
Porsche 968 spec for standard 1.1 mm head gasket is a measurement greater than 146.8 mm.
Images attached[ATTACHMENT NOT FOUND]
