Threads: 14
Mike,
Hard to tell the condition of the headgasket from that picture. I do see a couple of voids there so you had coolant going where it wasn't meant to. Don't know that you had leaking combustion gases though. Too oily.
I used a metal block and some very fine emery cloth and I used fine scotch brite pads. Nothing harsh that will scratch. I used purple power degreaser, and everything came out pretty clean. I cleaned the intake, oil separator, and the block while I had the room. The purple stuff worked pretty well in cleaning the pistons as well.
I didn't go with the wide fire-ring headgasket as I am not planning on adding boost. I got the top end gasket kit which pretty much included all the gaskets and seals I wanted.
Joel Wahlsten
(This post was last modified: 11-14-2015, 08:15 PM by
JWahlsten.)
Threads: 63
Hello,
Nice work pulling the head. I did that a few years back and used scotch brite pads and brake clean. I wore rubber gloves
and was careful not to get that really toxic stuff all over everything. It took many hours to get the surfaces completely smooth and clean. When Pete came by to pick up my head, he was suprised at how clean I got everything. I took that as a huge compliment.
Pete handled freshening the head and also took the intake and cleaned that and the valve cover gasket. When I got everything back it was just awesome. Clean and looking like new. I used a Widefire head gasket and everything worked out great.
I recommend one thing in particular - BE REALLY CAREFUL with the vacuum lines and the AOS (Air Oil Seperator). There is a little nipple on the top of the AOS where the vacuum line attaches - I managed to snap it off trying to pull the vacuum line out. Max from Provost was able to get it repaired, thanfully, because you can't buy a new one.
With Pete advising I felt I had someone who could verify my steps and take care of the shop work. And he helped me time the car when we got the belts back on. (You can rotate the crank - no worries.) He could not have been more helpful. Wish I still had the car but it was a great experience. There should be a thread somewhere about the project, which also included water pump replacement and every seal and gasket on the top end as well as the oil filter housing and the external oil cooler.
SOLD! 1992 - 968
Threads: 17
Indeed no worries rotating the crank , just get some paper towels dry and clean on top of the pistons , when it is al dry get your vacuum cleaner out and suck all loose bits of the top of the pistons .
Then there is no change you wil scrach anything .
I would not use oil , you only make things sticky for dirt etc .
And cover the the blok with paper towels or a cloth so it keeps clean and nothing can fall in there when working arround the engine .
Nothing worse than looking for a nut or somthing and thinking it might have found it's way in the engine .
volvo V70D5 Black
Porsche 968 amethyst
Threads: 13
I suppose no airco in that car....
