The part numbers are for the heater control rod clips that break and put the heater on full
There is a full troubleshooting guide for the heater on Clarkes garage website,
Your mechanic can use this to fault find, its for a 944 but the system is exactly the same
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Quote:Don't forget, the default setting for the hot water control valve behind the distributor is "on", so a disconnected or failed vacuum line will make the valve stay on and the heater core in the cabin will always be hot. Those plastic valves are prone to failure, so that may be a good place to look as well.
This.. I have fixed the failed vacuum line twice now.., latest was vacuum line connection disconnected when I got it back from OPC big service this year.., noted constant heat so knew what to look for..
Nacht Blau 968 cab, Wimbledon Green 993 coupe
Quote:This.. I have fixed the failed vacuum line twice now.., latest was vacuum line connection disconnected when I got it back from OPC big service this year.., noted constant heat so knew what to look for..
And that's what this forum is for! Keep an eye on that valve, the glue tends to degrade over time and fail at the worst possible time. I replaced mine with an all-metal unit, which required some minimal changing of hoses. If you change the valve, remember to bleed the air out of the system using the bleeder bolt on the top hose.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
+ audi part  for 15€ fits also, slightly thicker inlet, but at least it will be stiffer fit to hose.
1992 968 Targa with M030+M220
1989 951 M030 M220
If in doubt, FLAT OUT .
Interesting discussion and thanks all for the information, including substitute valves.  I'm now wondering whether to replace mine as preventative maintenance.  I doubt mine functioned at all during it's first 22 years of life as it was in the Middle East, but plastic and rubber do suffer in the heat (one day last week it was over 50C) so I wouldn't be surprised if the valve disintegrated without much warning.  I replaced the hoses around it when I did the water pump and timing/balance belts earlier this year, but didn't think to replace the valve itself.
BTW can anyone tell me why my Cab has a relay in the "rear window" spot?  I thought maybe it is just a spare, but there is a place for a spare relay and there's nothing in it.  So I don't want to remove the "rear window" relay in case it also has some other function.
Still waiting for:
1. Injector rail support bobbins.
2. Pin extractor/insertion tools.
3. Front shocks
We certainly have to become accustomed to a different delivery speed.....
my heater valve split in half  without any warning , just steam. glad that happened 100m from garage,
about  the relay, remove it and see if anything stopped working, simple.
1989 951 M030 M220
Hi Roboman, i'm also planning to change my shock absorbers.
Which ones did or will you order, as there is not much choice for the fronts.
I'm thinking about the Koni inserts.
J I'm not a racer so just bought standard shocks ...... Bilstein-B6-Stosdampfer-2x-Vorne-fur-Porsche-924-944-968/362995823871?  Euro 330 for the two inc post through ebay.fr, though they come from Germany.
Netopyer - thanks for your experience re the heating valve, time for a change I think!  Re the relay, sure I could swap it out (and hope I try every possible function) but I'm just checking if anyone has actual experience ..... I guess I'm really addressing Cab owners as I'm assuming for Coupes it is the RW-heater.  But thanks anyway, and if I don't get any inside knowledge then as you suggest is just what I shall do.
Have a good weekend y'all  (gracious that comes around quickly at the moment)
Can you post a pic of the relay and the location? I will check my car.
Do the valve, it's easier to do now.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Roboman, you don't have to be a racer for the Koni's.
They are adjustable and only around 30 euro's more, but also easier to install.
that's 30 euro a pair, so totally around 360,00 euro a set
J, too late but thanks anyway. For a change I'm letting the garage do it. I don't have a spring compressor and also I am keen to finish the house decorations so I can enjoy the rest of the Summer.
MCL I'll post the pic tomorrow- thanks.
Worked on the rear brakes yesterday and today. New rotors and pads. What a pain in the you know what. Fronts where so much easier. Hard to get to things when you don't have a lift. Took forever to remove the brake wear  sensor from the connection. gave up on installing new. Impossible to seat it. The set screw on the rotor frozen. (Common problem) so they had to be drilled out. After six hours my old body said STOP. To be continued.
MCL - here it is. The relay is the one with the 17mm socket on it, G3, Rear Window. Sorry to be brief, preparing for a party this evening. Thanks again.
bilstein B6 are considered sport  suspension, and very good. is it upside down technology also? should be.
1989 951 M030 M220
Yes, upside down I believe. And what difference does that make?
better ride , no foaming
1989 951 M030 M220
J I hope I've got to you before you possibly order from eBay. I received mine today and they don't appear to be what I ordered. It's late and today was our wedding anniversary so I'm not of a mind to investigate shock absorbers (maybe 30 years ago!) so I'll get back to you shortly.
For B6 on a 968 you need two threaded collars to insert in the tops of your old struts once you have cut the tops off at exactly the correct length, once cut the collars need to be inserted exactly the correct distance and then welded in place
Once this is completed then you need the correct tool to set the torque of the locking nut that fits on the collar
The collars are available from sportwagen.de at about 100 euros posted
If you message me directly I can put you in touch with a fella that does this on an exchange basis
Send him your shocks and the inserts and he will build them for you and ship them back
If you had gone with Koni almost the same applies, except you would need to cut the top off and then drill a precise hole in the base of the strut for the locating bolt for the insert
This is because all 944, 944S2 and 968 front struts from about 1986 on changed from screw on tops to crimped tops
Surgery is required no matter what option, and I bet if you back to your advert it says generic photo
Just to add the only full replacement is genuine Porsche at about £300 a side, and they will be between 10-15 years old off the shelf
Roboman, i already knew.
The pictures are just misleading/placed on a lot of site's.
It shows a complete strut, while you can only get inserts from both Bilstein and Koni.
Hope you still had a nice anniversary, congrats anyway
Waylander thanks for the offer, I'll give it some thought.
Thanks J, not good news about misleading adverts, but the anniversary was great.
Thanks guys Smile
Last Post by J.Elenbaas
02-15-2022, 05:25 PM
Last Post by Kim
06-22-2020, 02:14 PM
Last Post by az968
02-21-2016, 04:28 PM
12-25-2015, 03:33 PM
Users browsing this thread: 10 Guest(s)
