questio on brake bleeding
Quick question on bleeding brakes. What is the blue braided line coming off the brake fluid reservoir? Does it need to be clamped off before bleeding (I'm going to use the motive power bleeder). Thanks
rl, That blue hose supplies the clutch, no tying off. Fluid in the Power Bleeder should assure the fluid in the res. doesn't go below that blue hose, but keep an eye on it or you will have to bleed the clutch (which isn't a bad idea depending when it was last done).
Last Post by IndischRot968
07-21-2025, 11:46 AM
