Threads: 19
There are a couple of tests described in the <acronym title='factory service manual'>FSM</acronym> volume 1 under DME Diagnosis. Have never had cause to work on an <acronym title='mass air flow'>MAF</acronym>, so can't add anything. The tests described seem fairly straightforward.
'92 Midnight Blue 968 Coupe
Threads: 19
[quote name='tamathumper' timestamp='1371997878' post='144785']
Can anyone verify for me what their tach needle does when the car is turning over, before it starts?
Pulled the coil wire so it wouldn't start. Cranked as I would to start; no depression of the throttle. When I did this, the tach barely wiggled the needle. Hope this helps.
But, I'd agree with Flash, check out the wiring for the <acronym title='mass air flow'>MAF</acronym>. Stumble under throttle opening is most commonly a super lean condition.
Threads: 19
Don't be too discouraged by the <acronym title='mass air flow'>MAF</acronym>. Check out the simple tests indicated for the <acronym title='mass air flow'>MAF</acronym>. They aren't that difficult. As I recall you blow on the hot wire, and look for changes in the system to reheat it back to the correct temp with the added air going over it (that's basically how it works). It is a fairly simple control loop, and you should be able to at least check it's basic operation with a simple VOM.
Threads: 77
If you haven't cleaned and oiled your K&N filter yet, then it wouldn't have caused any issued with your <acronym title='mass air flow'>MAF</acronym>. The only time it causes issues with <acronym title='mass air flow'>MAF</acronym>'s is when someone goes to heavy when they oil the filter. If you just lightly oil it after cleaning you will have no <acronym title='mass air flow'>MAF</acronym> issues. Some people have hard opinions that a K&N filter will kill all <acronym title='mass air flow'>MAF</acronym>'s immediately, which isn't true as long as you are oiling properly..
The biggest killer of <acronym title='mass air flow'>MAF</acronym>'s is just age, I've already replaced mine at 100k miles.
Threads: 19
Just my 2 cents, but everyone who is running a boosted engine, especially if it didn't come from the factory that way should have at a minimum an air/fuel gauge (even a narrow band is better than nothing). There are quite a few items that can cause an engine to run lean, and you really should know it when it happens before it results in other issues. And, I'd also like to see an exhaust gas temp gauge as EGTs among other things are a product of both air/fuel and ignition timing, so you get a feel for how these two are playing together (for that reason, EGT gauges are very commonly used in internal combustion airplane engines).
It is really cheap insurance compared to the cost of an s/c or turbo setup, or bad results from detonation.
