01-02-2011, 01:48 AM
Hi there.
well - thanks to all so far who have helped me with the new car; have now driven the car 1500 km home, changed oil, plugs, cleaned up rotor, scared myself by driving off with the handbrake on - neccessitating removal of both rear rotors for a check-up - I'm starting to deal with other things....
car is generally hard to start - will have to crank over 10-15 rotations to get her going, then fires up, rpms drop to 500 or so, then within a second resumes back to 900, and idles well - slight hunting, but no stumbling on acceleration or other rough running. Smell of fuel in engine bay after start up -not in cab. once hot will randomly start well, or again, be hard to start...
Having trawled the forum I see there's a host of possible reasons for this - will go through a list and see if anyone can add any ideas
1 - Change DME Relay - (one on order) - but can smell fuel in engine bay, so presume pump is working
2 - change fuel filter - as above
3 - check for loose vacumn tubes - / leaks - (change HCV???) - interesting note - cab heater is very weak - far less so than I would expect for the amount of heat generated by a 3.0 l engine cooling sustem - so poss a prob here...? Coolent was changed with replacement of cambelt 2 weeks ago when I bought car - so poss air-lock in heating system????
4 - put on new rotor-cap ( old ones look "ok" - not mint, but not cracked or with signs of tracking around cap)
5 - CLean MAF sensor (will do!)
So - anything else anyone can add to the "to do" list??
will post some pics of car soon
Cheers
Chris
Cheers
Chris
