01-02-2013, 12:08 PM
I ran across something I'd never heard before, but it makes perfect sense - Summit Racing (great company - excellent customer service), in their description of the break-in oil I'm using, says that for optimal results, the oil should be heated to 180 degrees F prior to first starting the engine after a rebuild. I can see how this would help circulate the oil quicker to the critical components when starting a rebuilt engine for the first time, and maybe even minimize the lifter-clatter time, although the fact that I used assembly grease on all the critical parts (main, rod, and cam bearings, cam lobes, etc.) should mitigate most initial wear issues.
However, I love this type of thing, so, since I've put so much time, effort, and money into this project, I figure, what the heck, it wouldn't hurt to come up with a way to pre-heat the oil prior to starting the engine for the first time. The question is, how? I've found they sell oil pan heating blankets for this purpose, but that's just way too easy, so I'm wondering about DIY ways to accomplish the same thing. Heat gun? Space heaters aimed at the pan? Put a pot of boiling water on the jack and submerge as much of the pan as possible in the hot water (may be hard to get much of the pan submerged on our slanted engines)? None of these seem like they'd transfer enough heat to the oil to really heat it up much. Any other ideas from the creative folks out there? Thanks.
