Threads: 16
Has anyone ever found a source for the actual bearing which is pressed into the strut carrier? The action is fairly bumpy, and as I just did the cut-a-strut for the new Koni inserts, I figure I should replace these. I pressed one out.
It is a FAG 562300, which are evidently constructed of unobtanium, and warehoused somewhere behind the Iron Curtain. If I can't find one, I will just buy a couple of deep groove axial thrust bearings and made a couple of shoulder sleeves on my lathe (because 14mm is no longer a common ID in bearings).
TIA
Pat
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 45
You could make us all a few of those shoulder bearings it would be fantastic
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Threads: 16
I ordered some 20 x 42 x 13 deep groove ball bearings, and will start from there
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 16
I'm just going to change the bearing. The rubber remains untouched. The entire mount was intact on both sides, just the bearings themselves were questionable.
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 16
Thanks Michael, that was interesting reading. The rubber seems to be a damper, as was stated in those threads. Mine are not delaminated. Looks to me like the failure of the rubber would have to be total delamination, such that the rubber separates from the steel casing. Having taken the original rubber stuff off my 911, I can verify that it is no bargain getting that stuff apart. I guess if we look only at the top of the mount (the view from the engine compartment), the metal core "walking" off to one side would be evidence of partial delamination, or rubber fatigue. In my case, there is evidence of a very small amount of "walking", but no obvious delamination (you have to see this from the bottom, with the strut assembly apart). Disclaimer: I am not a polymer engineer. I do know when I pressed the bearing out, the rubber squashed a bit, so I guess it's still doing it's job..
You can see from the above picture that the rubber is laminated to the center core steel sleeve (for lack of better term), which actually carries the ball bearing. The outer mount plate and this sleeve are thus isolated from each other, and the body. I suppose if one wanted, they could eliminate the rubber completely, and weld the mount and core together, which would likely produce a pretty harsh ride.
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 16
Never had a weight. That must have been on newer cars. This is a MY92.
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 16
Update:
I called FAG, actually Schaffler, who owns them. I think they stil make the bearings, but the bearings are proprietary. Seems that they only manufacture them to the people that sell the mount assemblies. I guess if you know somebody....
I ordered some of those KLA strut mounts from Paragon. They are currently plan B.
I finally got around to making some bushings. I picked up two NSK 6302ZZ deep groove ball bearings, which are supposedly rated to take the axial and radial loads of the original bearing. These bearings are 15mm ID x 42mm OD, and just about the same depth. The inner sleeves don't protrude like the originals. Bushings were fabricated from 4130 steel. The bearings OD is a bit smaller than the OEM, so I am going to use a drop of Loctite 680 on them. I think this will work. If not, I yank it apart and go with plan B.
Pat Keefe
78 911 SC
92 968 Cab
01 986
Threads: 45
They look good should do the job fine
Threads: 16
I may have made the big end of the bushing about 5mm too long. I put the passenger side back together this evening. Looks OK. Worst case is maybe the strut travel will be reduced by 5mm or so. I am now thinking about the ball joints (while I'm in there :excl: )
Pat Keefe
78 911 SC
92 968 Cab
01 986
