08-18-2012, 11:44 AM
This is advice, mainly on how not to do things and a couple questions..
I received the new (correct) wheel bearings yesterday. I had already taken the old races out of the wheel hubs and was prepared to install the new ones.
What I should have done was to take the new bearing races and wheel hubs to a machine shop and have them installed by someone with a press. Would have cost me probably about $20 dollars and took about an hour.
What I did do was to try to install them with a seal & bearing driver kit from Harbor freight. What I have now is a mess. The outer races went in fine, absolutely no problems. The inner races.. well... both went in crooked and in my impaitence and frustration, I made things worse. I actually cracked one of the races and the hub has a ridge from me trying to pound the race in.
So I'm now trying to determine the best way out of the mess I've created for myself. Can the ridge be machined out? If I do, will the bearing race seat properly in the hub or do I have to get a bearing with a slight large outer diameter? Or should I just buy new/used hubs?
