[quote name='hot968' timestamp='1390955088' post='154713']
986 Boxster Thanks for the info yes it is a Club/Sport/930 steering wheel I am buying is it very complicated to remove old one and install this wheel? I think the hardest part is making sure the turn signals and horn continue to work- or do u lose the horn? Once the air bag wheel is removed the air bag light can't come on can it?
hot968, you need Porsche Part # 928-652-104-00 (Horn Contact). If you simply unplug the air bag and don't do any modifications the ari bag / warning light will go off ad soon as the battery is reconnected. The cleanest mod is to insert a 3.0 ohm resistor into the orange plug the the clock spring was plugged into.
Heres a quick run down:
1) Disconnect battery for at least half an hour
2) Remove the two T30 screws holding on the air bag
3) Gently pull on the air bag and it will come forward and carefully unplug the red connector on the back; I always tape over the plug with electic tape when storing air bags
4) Undo the the 24mm bolt holding the wheel on
5) Pull wheel off
6) Remove the two philips screws holding the clockspring on and trace the wiring under the dash this can be easily unpluged
7) Where you unpluged the clock spring from the orange connector is where the 3.0 ohm resistor goes
8) Insert the horn contact part #[color="#ff0000"]928-652-104-00[/color]
9) Install new wheel (I slide the washer over a screwdriver to help guide it onto the hub
10) Torque 24mm bolt to 34 Ft-Lb
11) Reconnect power and enjoy!
I'll still put together a DIY with pictures over the weekend.
