Threads: 2
Kaj, those photos look familiar.
When I did my brake job a couple months ago I was able to salvage all except two of the old vibration damper discs from the backside of the old pads. I had enough salvaged to reinstall in three of the calipers and thought it would be okay to just go without on the fourth one. Nope, it was the only one that squealed. So, up in the air with the car on four jack stands again because I wanted to rebleed the brakes as well. Just finished it up today. Fortunately its easy to pull the pads out of the caliper when there are no damper buttons to lock them in and it only took about 20 minutes mostly consumed with removing the sensors very carefully to avoid breakage.
I think I mentioned earlier that I elected to go with stock Porsche rotors and pads. I bought all new sensors (thankfully as every one of mine broke), but I forgot about the vibration dampers.
Tomorrow Ill finish cleaning up the rotors, but the wheels are going to stay off the car for awhile as Im having them refinished and having new tires mounted ($$).
Tim
06 Cayman S, Guards Red
Threads: 45
I pretty sure they are made by ATe,
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Threads: 49
I always always always wipe my down with brake cleaner, followed by alcohol on a clean cloth.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
Wait till you see what comes off of the rotors. Cutting oil, metal shavings, and just general nastiness that would get all over your pads if you didn't clean it off. Keep wiping them down until the cloth shows no more residue from the machining process.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 167
Threads: 167
If it was a Porsche it would change a 20 minute repair into a NLA 6 week search for a new bolt ordeal
