Threads: 27
I noticed yesterday when I looked at my floor mat on the passenger side that the color had gone from black to white on the top left corner. So, I pulled the mat and noticed fluid puddled in the top left corner of the passenger footlwell. I cleaned it all up, pulled out the floor mat and let it set over night. The next morning it was dry and did not show any signs of leaking fluid. I drove to work this morning and when I came home there was a puddle of radiator fluid again in the passenger footwell.
I am worried that my carpeting is going to be stained and turn white from the radiator fluid leaking all over the carpet. Anyone have this problem or know what is going on?
Threads: 25
I've never see anti-freeze stain carpet white (but I haven't seen everthing). My first impresion (with out seeing it) would be leaking heater core or heater hoses.
Rick
Threads: 27
968rz,
I have not heard of ant-freeze being able to stain carpet either but something did because my black floor mat is now white in the corner. I plan to get it to my mechanic in the morning and hope it does not cost me an arm. The smell is the worst. I hope I will be able to clean it out. Thanks for the comment!
Threads: 35
Any chance you have a rust thru from the battery box, and rain water is leaking down past the battery and getting a bit of battery acid mixed in? That will turn a carpet all sorts of bad colors!
1994 968 Coupe, Red / Cashmere/Black, 6 spd, [acronym="Limited Slip Differential"]LSD[/acronym], Part Leather, Alpine, Hidden Radar, Airbox Mod, early Engine Decore Panels, more to come!
2002 MB Silver Arrow SL500 AMG Pack, one of 750 imported.
2008 SX4 Sport, 2004 GMC XUV, 1997 Towncar, police pack sleeper.
Threads: 23
Sounds like a heater core. I haven't had the issue on the 968, but I did have it in a few other cars. Someone else may be able to post how easy it is to get to, or if you have to pull the dash.
You should be able to tell by the smell if it is coolant.
'13 Lexus GX
'04 BMW 525
'92 968 Cab Black/Grey
Corvette Z06 - Dedicated track car (Sold)
'94 968 Cab-Guards Red (Sold)
Threads: 167
Bob Kovacs presented a solution at the 968 Celebration in Virginia. It is common for the battery box to rust through and leak into the foot wells. The battery needs to be removed and the area dremelled out and lined with fiberglass(?) and epoxy.
Regards,
Threads: 27
Well,
My Mechanic/tuner told me that the leak is coming from the heater core. I am not exactly sure what that is but I assume it has to do with the AC/Heat. In any event, @ $450 for the parts and $1,000 for labor. I was told that the heater core is located in the center of the car and that the entire dash would need to be removed thus the cost of labor. It will take several days to finish barring no other issues. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Threads: 25
[quote name='flwbyu' post='27810' date='Nov 10 2006, 07:01 PM']Well,
My Mechanic/tuner told me that the leak is coming from the heater core. I am not exactly sure what that is but I assume it has to do with the AC/Heat. In any event, @ $450 for the parts and $1,000 for labor. I was told that the heater core is located in the center of the car and that the entire dash would need to be removed thus the cost of labor. It will take several days to finish barring no other issues. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />[/quote]
The heater core is like a small radiator in the dash. The water pump circulates the warm engine coolant thru the heater core (heat exchanger) to warm the cabin.
As for the cost (?) considering its a Porsche thats probably not bad, especially since the dash has to come out (real PITA doing that, been there <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> )
Rick
Threads: 27
Quote:The heater core is like a small radiator in the dash. The water pump circulates the warm engine coolant thru the heater core (heat exchanger) to warm the cabin.
As for the cost (?) considering its a Porsche thats probably not bad, especially since the dash has to come out (real PITA doing that, been there sad.gif )
968rz,
I appreciate the description of the heater core. Understanding the mechanics of my porsche is one of those knowledge sets I am still learning. As for the cost, I have no objections because my mechanic/tuner is excellent. Besides, there is never a good time for car problems. <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
Threads: 167
Might be a good time to do some ogf the "while you're in there...." type things..Gauges, lghting, etc. Just a thought.
Regards,
Threads: 25
Wolfgang,
Welcome to the Forum and 968s also thanks for the input about NOT having to pull the dash to get the core out, it makes the idea of having to do it much easier to swallow (not that I need to but you never know)
Rick
