Hi,
On my 968CS '93 the footwell ventilation stopped working. Although I have the electrical schematics for the A/C system, I do not know which valve controls the ventilation and where to find it.
I already took apart the A/C control panel and looked under the drivers side dash to find any loose connectors, burn spots, strange noises etc. I saw the controlpanel is quite expensive.
When the upper ventilation rheostat on the dash control is set, you can hear a little electro motor or servo run, but this is missing when the lower/footwell control is moved to either side.
It is probably this servo that is broken, but where can I find this thing?
Gtz,
Martijn
