I can confirm 951 (turbo) rad fits and works perfectly in my 968. Installed mine and very happy with it.
As the previous poster noted, the 951 rad requires a blanking cap aka "Block Off Plate" part number 944.106.103.02 when fitted to a 968. The good news is that the part was cheap and readily available - got mine from an official Porsche Centre.
And then came the problem.
The cap I fitted has just failed (after a few hundred miles). At installation I clamped it with a Porsche-provided Norma-brand clamp (20-32mm with nice rolled edges etc) - not an
el cheapo clamp. The cap is a fairly thin soft material (some kind of flexible polymer) quite unlike the tough, fibre-impregnated material used on main rad hoses. The clamp cut thru' the cap - even tho' I used (what I considered to be) moderate torque to tighten it. The clamp had a 9mm band width with an embossed thread. The thread as it appears on the inside is quite rough to the feel.
I've ordered a replacement cap and 2 Norma clamps, this time with a 12mm band width in the hope that the wider band will not cut-in to the same extent. Two clamps so I can put them side by side to give a wider area of clamping with (hopefully) less clamping force required.
There seem to be 'better' (more suitable) clamps out there. For example, Norma (Americas) offer the
Breeze Liner clamp - described as
"A general purpose worm-drive perforated hose clamp with extended band as an inner protective liner to protect soft surface hoses (Silicone and others) from damage, while maintaining a true concentric seal".
Can't seem to find these in the UK.
I have also looked at T-Clamps and spring clamps etc.
Update: Have just found a "Mikalor" Worm Drive Hose Clip - stainless steel - W: 12mm - 20-32mm available in the UK - and appears to smooth on the inside.
I'd welcome any experiences/suggestions from forum members on the best way forward.
