Threads: 49
I just discovered a leak in my 3 year old radiator. It seems quality control is not what it used to be, in that the leak looks like it has been there for quite some time- perhaps since it was installed.
I know someone with a 951 unit that is close to new (it was used for about a month), and he claims they are the same, with the exception of the tube that cools the turbo. They do indeed look identical. Has anyone had any experience with the 944S2/951 radiator in their respective 968?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 167
Threads: 49
If the radiator passes a pressure check I am going to get it. Now, any suggestions for how to cap that extra line for the turbo?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
order the cap from OPC
Cap 944 106 103 02 its costs £4.50 here so i would guess about $7-8
Clip 999 512 392 00
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Threads: 177
Sam Sparks, I had the exact same problem with my new radiator for my 6-speed - the extra port I was told was for a tip and it was a line to cool it. My radiator was a 968 rad that was installed by RS Barn. It did the same thing after about 3 months. I noticed that coolant would sometimes come out and other times not, and it was a bit of a job to figure it out. I ended up needing to move the clamp further ahead and it seemed to work. I never did figure out what to use to replace it. The car is gone so I haven't worried much about it.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 45
I have seen a few manual rads back in stock online
Threads: 45
Buy one now and put it away, that is the only sure fire way of having one in twenty years, I will be to old and infirm by then to worry about it
Threads: 45
If I have any more heart attacks that might be sooner than I might hope
Anyway had a great day out at Cranleigh classic car show, 700 cars and only two 968's, one mine
And loads of really nice unusual cars, a 1967 Honda S600 coupe not seen one of those for about 20 years.
Threads: 45
Threads: 13
Yes tip radiator is different.
This because there is a section for cooling and preheating the atf fluid from the tip mounted inside it.
Threads: 49
Just make sure it has the threaded bung for the fan switch. When I was looking at them when mine started leaking I noted that some did and some didn't.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
