04-27-2005, 11:00 AM
I just purchased a new PORSCHE timing belt for my 968 (no. 944-105-323-02). The box says Porsche...and the Belt has the Porsche numbers on it..but it's actually made by DAYCO Isoran Made in Italy 119 RPP Plus 254 #SN 04286119. Obviously made for Porsche by another party. Cost was about $86 dollars. Yes...it's more money, but I wanted to get what's supposed to be the best...but I'm not sure it's all that much different than the cheaper belts available?
At first I was freaked out when I opened the box. The accompanying card explaining the T-belt tensioning check at 2,000-2,500 miles was stamped across in bold letters...NOT FOR 968. At first I thought the belt design might not be right for the 968, in spite of nos. being right so I called the dealer and was told that the belt is actually for the 968 but that the tensioning is not required of the belt since the auto tensioner of the 968 does this. Therefore, the NOT FOR 968 note really means, NO TENSIONING CHECK REQUIRED FOR 968 APPLICATIONS. At least I hope that's what it means. The belt lobe tips have a little groove across the face...a little different than belts I've seen for the 928.
Is the auto tensioner so good that you don't need to check belt tension? What about on initial belt install...do you just install it, pull the pin out of the tensioner and hope that the tension is OK? Sounds bit primitive/or advanced to me. I'll be checking with the 9201 tool anyway. 968 or 928 T-belts and blind faith are not a good mix.
Harvey
Harvey
