10-06-2010, 08:10 AM
It is worth noting that if you are using a synthetic oil for the first time, or if you do not know the history of the car/engine, plan of changing the oil fairly frequently after you do your first change. THe reason for this is the cleaning agents work much better in newer oils and will effectively sludge up the new oil very quickly (excessive carbon loading). The old deposits will be broken down, which will deplete the lubricating properties of the oil. sometimes adding very good oil can lead to a failure simply from its ability to remove all of the built up crud from the oil galleries, etc.
Oils are a blend, regardless of brand. There used to be around five (5) additive manufacturers worldwide, that create the additive package that is used in every oil. Each oil sold on the market consists of a base oil and an additive package. From memory, when I used to do this stuff, zinc works well under high friction environments and is usually added to hydraulic oils. Be careful however, as it eats any silver in the engine. We had journal bearings in traction motors that we thought were showing cavitation, which was actually the zinc corroding the silver away under pressure and heat.
So it is not surprising that two oils have similar component levels, it is probably the same additive package added to both, but slightly different base oils.
THe most important part of the oil is the additive package - not the base oil. This is particularly true for synthetics, as the base oil is manufactured to a specification.
Food for thought.
Food for thought.
