Threads: 77
It sounds more like you have air in the system and it needs to be bled. I would bleed the brakes and clutch before replacing things. If that works then replace the fluid and run with it for a while.
Also I would try and find a good independent Porsche shop to work on the car, the dealer is usually not the best place. Your local Porsche club in St Louis should have some suggestions.
(This post was last modified: 05-23-2014, 08:02 AM by
banditsc.)
Threads: 77
It can be difficult to bleed it correctly. I would still get a second opinion from a independent shop specializing in Porsches, I wouldn't' trust the dealer. According to your local PCA site, it looks like Reid Vann might be an option for a second opinion, at the least I would expect them to cost less than the dealer.
