I believe there are a number of factors "at play" here (sorry about the pun) .....
1. An experienced mechanic friend of mine informed me years back that depressing the clutch and engaging the starter was not a good idea as it put undue forces onto a cold crankshaft bearings .... fair enough I thought, and given that I was taught to park in neutral unless on a steep hill, no worries. But these days many cars have a "safety feature" of pressing clutch prior to starting .... is this a long term spare parts replacement strategy??
2. The clutch release on the 968 (I'm making an educated guess here because of my 944 ownership) is a combination of two adjustments; one of which actually releases/engages the clutch plate, and the other assists the pedal return. If these are not correctly set then one will get clutch slippage and/or the clutch will engage "early" and the cruise control will not work.
3. Worn/leaking master/slave sytem/aerated clutch fluid - the usual maintenance.
4. I was unaware on fire wall cracking .... great piece of information, thank you!
Item 2 is interesting ... I recall a thread about "why doesn't my cruise control work?", but at that time I had only just joined 968Forums so was busy scanning the various threads instead of trying to help ..... if whoever has a cruise control that doesn't work, please ensure the clutch release switch is functioning/correctly set.
I know nothing about 968 pressure plate selection.
Cheers
