09-08-2014, 08:11 AM
My car is doing a couple of things it shouldn't. Firstly the throttle is lumpy when cold and secondly the engine tries to stall when taking foot off the accelerator when cold (revs drop, especially when the air temp is cold). Its always had the lumpy throttle when cold, it started doing the stalling thing after a top end rebuild so I think this is likely two separate issues.
I've checked a number of things including:
- Changed ICV for a used replacement
- Changed and tested DME Temp sensor
- Changed and tested <acronym title='throttle position sensor'>TPS</acronym>
- Tested hall sensor
- Passed a vac leak test
My mechanic had a look last week. Checked for faults using a Hammer (3rd time in 6 months) and nothing comes up. Ran the car with the Hammer attached. Car runs rich when cold with electronics trying to even the mixture. Runs perfectly when warm.
He's given me a few things to try and also invited me to cannibalize his ClubSport for parts to test parts. Any thoughts?
(This post was last modified: 09-08-2014, 08:11 AM by dry664.)
