Threads: 46
[quote name='mntnsvx' date='Feb 26 2006, 08:50 AM']Hey guys,
I am a relatively new 968 coupe owner, who unfortunately had an accident 35 days after buying the car. 5 1/2 months later, I got it back.
Here's my problem. My son and I took the roof off one day for fun and sun, and now it doesn't want to latch completely in back. I'm following the manual's instructions as best I can, but the glide levers in the back are not latching into the rails.
How do I do it?
Kevin
[right][post="16565"]<{POST_SNAPBACK}>[/post][/right][/quote]
Kevin, I had this same exact problem yesterday on our Norcal 944/968 fun run. the knowledgeable folks on the run helped me fix the problem this way:
there is a manual latch retractor in the back L of the car in the trunkspace:
1. remove/peel back the left side carpet behind the wheel well
2. examine underneath, behind a circular hole in the metal there will be a hex nut. This may be covered by a black plastic shell, if so pop off the shell to expose the nut
3. turn the nut, the latches will move, find the right direction and retract them all the way down.
If you need addl help I can snap some pics for you.
cheers! and tell us about your coupe!
Sean - San Francisco
Threads: 46
[quote name='mntnsvx' date='Feb 27 2006, 02:32 PM']Thanks, I would like some pics. I peeled back the carpet, and didn't see the hex nut or shell.
[right][post="16620"]<{POST_SNAPBACK}>[/post][/right][/quote]
K, I'll try and snap some tonight when I get home. It's been really stormy out here in Norcal and I don't have a garage, so we'll see if I can get a few dry minutes.
(This post was last modified: 02-27-2006, 07:47 PM by
ether_joe.)
Threads: 46
okay so check this out, the power is out in Alameda tonight due to very high winds. Get home, browse through the house with my handy pencil flashlight. Thinking to myself, 'well the camera is battery powered, and it's not raining, so might as well take the pics and post when the power returns.'
I take the pics, and then realize that the lights inside are back on. So whaddya know, the karma from my good deed lit up the whole neighborhood! <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
here's the pic of the shell. My left hand is directly behind the left rear wheel well:
another pic:
closeup of the assembly (the camera is upside down at this point)
I didn't want to take the shell off because it's a little bit loose on mine, don't want it falling off permanently.
BTW i don't know what the second nut is beside the shell (R side of the picture which is actually left since the camera is upside-down), probably a manual somethingorother, somebody else can shed light on that.
HTH <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Sean
(This post was last modified: 02-28-2006, 01:51 AM by
ether_joe.)
