Threads: 14
While raising my roof a while back I heard a pop/snap and the roof just fell back down and the arms retracked all the way back. Then, of course, I tried working the switch back and forth a few time, duh....Nothing....
I did a search for the typical gear repair and started taking things apart to see what I had. I found the plastic tube piece just off the motor was separated, not sure if it is suposed to be. And by working the switch, the motor had pulled the cable back into the fender compartment and now it wont go forward, only back.
Does anyone know what I'm dealing with here?
I took a couple of pics but can't seem to upload, and they're not posted anywhere on the net for a link... <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
TIA,
Mike D.
Mike D.
'94 Metalic Slate Grey Coupe w/ M030
'74 914-6 3.0 Hot Rod
Threads: 14
Mike D.
Threads: 7
Anybody fixed this problem? My motor and cable works fine. But the tube extends when I
try opening the roof so it won't go up. When I close the the tube returns back to the motor.
